Code 13 Baro pressure malfunction
Old Sep 8, 2005 | 05:23 PM
BEEYOND's Avatar
Default Code 13 Baro pressure malfunction
91 Teg 5spd. no matter what ecu i use same code 13. changed MAP and same thing. Seems like no one has figured this code 13 completely. Some say change the baro sensor, but where is it in the DA model. I know in the obd1-11 it is built within the ecu, but please if anyone know where the baro sensor is in the 90-91 TEG please post it.... post pix if possible.. if not just describe where!!!
hope someone can finally help solve this crappy code 13/baro sensor dilemma.
Old Sep 9, 2005 | 09:31 AM
BEEYOND's Avatar
Default Re: Code 13 Baro pressure malfunction (lsvtecpower)
that's what I thought.. seems like no one can solve this code 13... at least if someone can find out where the baro sensor is in the 90-91 TEG that would help.. come on people with helms/haynes/etcccc... HELP!!!!
Old Sep 9, 2005 | 06:45 PM
slomofo's Avatar
GDD Member
Baro/MAP - usually same thing.
Try searching the MAP wiring for opens, maybe the vaccuum source is ****, maybe the TB gasket is bad. . .
Old Sep 9, 2005 | 07:30 PM
rainforest's Avatar
Default Re: (slomofo)
ive seen this code only when people wire up things to the computer wrong. thats the only time i have seen it. its inside the ecu and calculates the air density (the altitude you are at).
DA_zooooms
Aug 10, 2009 09:08 PM
d_boi_swag
Jul 5, 2009 12:14 PM
Flexmyrex
Aug 16, 2002 08:46 PM
NZcrx88
Aug 9, 2002 03:18 PM
.brad
Feb 26, 2002 03:30 AM
