code 1 on my b16 motor
Old May 15, 2004 | 01:57 PM
4ghatch's Avatar
Default code 1 on my b16 motor
can anyone tell me what code 1 is and how to fix it? I just got it all wired up and tried to start it up the other day and i get nothing (not even a click from the starter) please help
Old May 15, 2004 | 03:08 PM
IMALLSLO's Avatar
Default Re: code 1 on my b16 motor (4ghatch)
Starting problem has nothing to do with code 1. Code 1 is a miswired or not plugged in o2 sensor. For your starter problems check the black wire on the starter solenoid. It is easily pulled off while fiddeling with other things. If its on nice and tight check fuses. If fusues are good take a test light and have someone key ignition the starter. You should have 12v when the ignition is put in start. If its not there then you got some wires to track down. If you have 12v it may be a bad starter.
Old May 15, 2004 | 04:27 PM
4ghatch's Avatar
Default Re: code 1 on my b16 motor (IMALLSLO)
the black wire is conected and the fuses are good too... how do i cheack for 12volt again?
Old May 15, 2004 | 06:47 PM
4ghatch's Avatar
haha. i didnt have a ground seup on the the trany yet. now im throwing code 4
4Greenback$$
Honda Ruckus and Scooters
Mar 31, 2019 04:10 PM
poprocksncoke
Feb 10, 2014 03:07 PM
91efbluehatch
23
Nov 14, 2011 11:12 PM
hybridpatient95
Oct 19, 2005 04:31 PM
