Coasting Myth!! AT & MT
Old Apr 9, 2009 | 06:43 AM
  #51
EJAYATE's Avatar
I Deliver
Default Re: Coasting Myth!! AT & MT
"Coast and Burn" only works if you shut down the engine completely during the coast part. Burn, turn on engine accelerate to coasting speed, shutdown coast down to a slow speed and do it again.DOES NOT WORK FOR STREET CARS only ultra light (under 70lbs vehicle wheight) .5-1hp bubble cars.
Old Apr 9, 2009 | 10:20 AM
  #52
DC_Legacy's Avatar
Originally Posted by Ash J. Williams
can't say about all the cars, but hondas do turn off the injectors at no load and TPS at zero.
OP, using the Ectune datalogger heres a screen shot of my motor under idle conditions and while throttling down in gear (foot off the gas) for comparison.
Below is my engine under idle conditions. Notice in the display box circled in green is the Engine speed at 841(RPM), Throttle posistion 0% (TPS), Injector Duty Cycle 2%. Vehicle speed and gear is circled in green in the box to the top right.
Below is my engine while throttling down/coasting with my foot off the gas. Notice in the display box circled in green is the Engine speed at 3130(RPM), Throttle posistion 0% (TPS), Injector Duty Cycle 0% due to the Fuel Cut activation (notice the green light FCut in the Outputs box in the display panel). Vehicle speed and gear can be referenced in the box to the top right.
Old Apr 9, 2009 | 11:37 AM
  #53
Uncle Ben's's Avatar
Cogent Argument Enthusiast
Originally Posted by xtonycrx
The engine is definitely taking in air but no combustion is occurring because there is no fuel to burn.
Ok, maybe it's not combustion, but it is still a power cycle, with air being compressed at about the rate of 10:1. The compressed air is still going to push the piston back down.
Old Apr 9, 2009 | 11:39 AM
  #54
Originally Posted by Knightsport
I swear someone just said there was zero fuel consumption under the aforementioned conditions. Don't look at me, I'm not the one making up ****. lol
I are confused. I thought you meant under engine braking, which some refer to as coasting.
Old Apr 9, 2009 | 11:42 AM
  #55
twentyhurtz's Avatar
ha, post funny!
Old Apr 9, 2009 | 01:18 PM
  #56
phateless's Avatar
Load makes a far bigger difference on fuel consumption than rpms. A civic si spinning 4500 on the freeway going 80 mph on cruise control can still get 35 mpg, because it doesn't take much fuel to maintain speed as opposed to accelerating which burns a lot of fuel. The same car, constantly going from 60 to 70 mph and back down, will get high 20s.
Old Apr 9, 2009 | 04:35 PM
  #57
fcm's Avatar
fcm
Old Fart
The only way there is 0 fuel consumption is if ign. is turned off, nuff said. 94
Old Apr 9, 2009 | 04:53 PM
  #58
GetawayInMoscow's Avatar
When you coast in gear without touching the gas the injectors will turn off. If you have a wideband on your car it will lean all the way out as there is no fuel.
Old Apr 9, 2009 | 07:33 PM
  #59
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
or the tank is empty?
you are wrong, BTW, nuff said
Old Apr 9, 2009 | 07:35 PM
  #60
not really, because the engine is attempting to compress the other two cylinders (on a four banger) what makes the cylinders move is pure inertia.
some of you people (and i don't mean you, ben) need to go back to school.
Old Apr 9, 2009 | 08:55 PM
  #61
tnxx's Avatar
Just learned something new.
Old Apr 9, 2009 | 09:02 PM
  #62
So suffice it to say that rolling resistance and friction ar the only positive forces that slow the vehicle down during engine braking? What about gravity pulling the pistons down on intake and power strokes?
Old Apr 9, 2009 | 09:55 PM
  #63
~sp33~'s Avatar
EFB055
No, no, no. I got that.
You couldn't "pop the clutch" in a rolling MT car to start it if that wasn't the case.
Someone said earlier that NO fuel is needed to maintain idle with the car in neutral, which is not the same as what you're saying now.
Oh, few.
No, because it would be countered by the exhaust and compression strokes. Perhaps on a Boxer engine though
Aerodynamics also play a large key.
JNS
Transmission & Drivetrain
Jun 21, 2016 07:32 PM
EJeff8
32
Nov 13, 2010 08:32 AM
sxm109
Honda Civic (2006 - 2015)
Mar 22, 2010 06:06 AM
5800vtec
Jun 6, 2008 12:41 AM
vti-R
Oct 8, 2001 06:55 AM
