Clutch Swap
Old Mar 25, 2008 | 02:24 PM
JScott3d's Avatar
Default Clutch Swap
I have a 93 ls with the stock cable trans. I need a new clutch and I have a spare of a 95 ls. Now when I look at acuraautomotiveparts.com and prostreetonline.com it shows the clutch being the same from 92-97 as being the same (with a differnet throwout of course). But when I set the disc on the shaft it seems loose and does not fit snugly. IS there a difference or will it work?
Old Mar 25, 2008 | 07:16 PM
JScott3d's Avatar
Anyone? It seems like the main shaft is a smaller diameter then the clutch
Here is a picture of what I am talkin about. I am pushing the top of the clutch back as is sits on the shaft. It moves about 1/4 in or so. and it will twist on the shaft just alittle to.
Modified by JScott3d at 10:57 PM 3/25/2008
Old Mar 26, 2008 | 12:33 AM
importdude2000's Avatar
make sure your transmission is a ys1
mabe someone swaped in a 90-91 small spine transmission
Old Mar 26, 2008 | 02:03 AM
JScott3d's Avatar
the trans code is S1. Does that mean its a 90-91?
Old Mar 26, 2008 | 02:30 AM
Default Re: (JScott3d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JScott3d &raquo;</TD></TR><TR><TD CLASS="quote">the trans code is S1. Does that mean its a 90-91?</TD></TR></TABLE>
YES!!!
so you need a Small spine clutch
i had a feeling that was the problem
Old Mar 26, 2008 | 05:33 AM
JScott3d's Avatar
Can I just get the disc or do I need the whole clutch kit?
turbo-crx
Transmission & Drivetrain
Dec 5, 2008 11:56 AM
JScott3d
Mar 27, 2008 08:15 AM
scanz89
Feb 12, 2008 12:53 AM
gtfour43
Jul 16, 2004 08:12 AM
