Clutch Squeak?
Old Sep 24, 2003 | 02:49 PM
The Notorious Frosty's Avatar
Default Clutch Squeak?
Alright here is the deal, I have a 99 ex coupe with 61k miles and when I press and release the clutch it makes a squeak noise. At first I thought it was the pedal but it is not, it's something internal. Any ideas? Is my clutch going to take a **** on me soon?
Old Sep 24, 2003 | 03:01 PM
pro1342's Avatar
Default Re: Clutch Squeak? (Frosty18)
Most of the time, the release fork that the slave cylinder presses in needs some lubrication. It pivots on a "ball" inside the clutch housing, and will squeak if it becomes dry. Remove the boot, and spray some WD40 on the backside of the fork. See if the noise goes away...if not, may need a clutch.
Old Sep 24, 2003 | 03:03 PM
Default Re: Clutch Squeak? (pro1342)
ok will do thanks for the tip
Old Nov 7, 2003 | 09:32 AM
PupaScoopa's Avatar
Just be careful where you spray... if it gets on the disc, the clutch will slip until the WD burns off.
Old Nov 7, 2003 | 10:02 AM
Default Re: Clutch Squeak? (PupaScoopa)
I think I managed to get it on the disc because it felt like **** for awhile but feels normal now..
Old Nov 7, 2003 | 10:29 AM
sleepN's Avatar
Wd-40 will solve it for now but it will come back again, Honda recommends high temp grease, so I would take the time and grease it up good.
Old Nov 7, 2003 | 10:51 AM
LudemanDan's Avatar
Mine does that in the morning when it's cold, but as soon as it warms up the squeak stops (movement of the pedal). I just assume it's the pedal spring or something.
Then again, my clutch has 140,000 miles on it.
Old Nov 7, 2003 | 11:52 AM
Ricey McRicerton's Avatar
Default Re: Clutch Squeak? (LudemanDan)
Mine squeeks in the morning when it's cold as well. It has never given me any trouble though, so I don't sweat it at all.
Old Nov 7, 2003 | 02:41 PM
EG6[B16A1]'s Avatar
Default Re: Clutch Squeak? (Ricey McRicerton)
My clucth pedal squeaks, do you think I can spray WD40 on it?
Old Nov 7, 2003 | 07:02 PM
vtekstorm's Avatar
bro i got the same car and same milage as you i got the same squeak when my car was stolen they took the tranny out to check if anything was bad and nothing was wrong . youll know when your clutch takes a **** on you when the pedal feels like **** liek if it was harder to press than it does normally
amej8
Honda Civic (2006 - 2015)
Oct 5, 2011 06:59 AM
ls2poweredgoat
Apr 24, 2009 02:24 PM
jdmcivicferio
Jul 9, 2004 02:15 PM
sil99civic
Jan 20, 2004 08:44 PM
rockwilda
Jun 19, 2002 03:57 PM
