clutch slipping/problems
Old Feb 12, 2005 | 03:31 PM
B18EG6's Avatar
Default clutch slipping/problems
hello-
My clutch is going bad, and Id like an input as to some possible causes.
The symptoms:
-Clutch pedal engages very close to the floor, lost some pressure in it
-Impossible to get into or out of gear when the car is on
-If I start the car with it in gear, and keep my foot on the clutch, the car lurches foward like im engaging the clutch
thats pretty much it. I added some clutch fluid to the resevoir and noticed a little difference in pedal feel, and the car drove for about 1/4 mile, then it started acting up again
Any ideas on what to look for when I open it up? TOB? Pressure plate? Leak/bubble in the line?
Thanks!
Old Feb 12, 2005 | 03:44 PM
Lord Helmet's Avatar
Default Re: clutch slipping/problems (B18EG6)
could be bubbles in the line. flush it out before you go on, besides it's the least expensive route you can go.
Old Feb 20, 2005 | 06:48 PM
blaster834's Avatar
Most likey no or low fluid
Old Feb 20, 2005 | 07:16 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
yea, if it's a hydro clutch (which i'm sure it is), check your fluid. if it's low, check for leaks. fix any broken parts, bleed the clutch cylinder, and make any necessary adjustments.
andlude
Apr 5, 2012 07:45 PM
CraiGlOl
Jul 9, 2009 07:52 AM
evade_07
Dec 13, 2008 10:15 PM
clkio
May 8, 2007 05:30 PM
boosted_lude
Jan 27, 2005 04:54 PM
