Clutch Problems
Old Feb 22, 2005 | 04:20 PM
yellowctr97's Avatar
Default Clutch Problems
I just reciently put in a stock clutch in my B18C.. i normally rev it to about 8.5...the other day i had it pinned to 8.5 and it reved to 8.7 and it sliped off...anyone have any ideas of what is the problem...maybe to much on the clutch being that its stock?
Old Feb 22, 2005 | 06:12 PM
dunkd's Avatar
did u break in the clutch? (if it was new)
Old Feb 22, 2005 | 08:59 PM
neogenesis2004's Avatar
Default Re: (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">did u break in the clutch? (if it was new)</TD></TR></TABLE>
in addition to that, did you resurface the flywheel?
Old Feb 23, 2005 | 11:08 AM
Default Re: (neogenesis2004)
what is breaking in the clutch?...i mean its been a good month or two...and no i didn't resurface the flywheel could that be one reason?
Old Feb 23, 2005 | 12:03 PM
Default Re: (yellowctr97)
not resurfacing could definately be a problem. Breaking in the clutch is just driving easy on it for a good 500 miles before taking it over 4-5k rpms. Also no clutch dumps either. The reason you need to resurface is because the flywheel is worn to the old clutch disc. You need to resurface to make it able to wear to the new one.
Old Feb 23, 2005 | 03:39 PM
alright thanks i'll take and get it resurfaced asap...i mean it is a stock clutch from advanced hopefully resurfacing will eliminate the slipping
Old Feb 23, 2005 | 04:22 PM
just make sure you drive easy on it for a couple tanks of gas. shift at around 3-3.5k
SpOoNisMyFriEnD
May 11, 2005 02:18 PM
danny98r
Jun 24, 2004 12:15 PM
dragster
Feb 12, 2002 01:29 AM
