is it clutch problem or clutch slave cyl. problem?
HI all. Does anyone know the operating range of the clutch slave cylinder? I've replaced the master cylinder and the slave cylinder has absolutely no leaks, but its still hard to shift. (especially downshift to 2nd gear). We bled the thing to death to make sure there was no air trapped. The operating range of the cylinder seems like it could go out much further but I was told it shouldn't be required to push out 100% of its range to have the clutch fully disengaged. So the next step is replacing the whole clutch kit, maybe the fork is bent? is this typical? The clutch does not "slip" at all. Of course I don't want to change out the clutch if I don't have to. Thanks.
Damn, I guess you Q. and A. your own thread. If that's the problem you're having, take the next step to find the solution. Good luck on taking out the Tranny and clutch, it's a B*TCH, cause I did...
what kind of clutch do you have? is it like after market rated for some ridiculous power range? if so, the PP might be too stiff
Where does the clutch start engaging? What I mean by that is how far off the floor is the pedal when the car starts moving. Have you tried adjusting the pushrod on the master cylinder? If the clutch engages close to the floor you will need to make the pushrod longer.
I'm not sure what clutch is currently in it.
Thanks
Its possible your clutch is just worn out or broken. I highly doubt the clutch fork is bent. When it started happening did it happen all of the sudden or gradually over time?
i had a similar problem, but i couldnt shift at all. stayed in neutral.replaced everything like you have and had same problem. swappe dout my act pressure plate for a new one, and voila works again.
bhergh
Feb 11, 2014 05:28 AM
