Clutch install question(b16)
Old Jun 12, 2003 | 08:00 PM
STEV3-O's Avatar
Default Clutch install question(b16)
Anyone know the torque specs for the flywheel, and pressure plate on a b16? Also for the axle can i torque it down to the 96 civic, even though i got a 95 hatch? My friend told me to torque it to 134 lbf-ft( the spindle nut)?that sound right? i really appreciate this thanks.
Old Jun 12, 2003 | 08:49 PM
PhatOptimo's Avatar
Default Re: Clutch install question(b16) (sleepingeg6)
Flywheel is 76 ft. lbs. and pressure plate is 19 ft. lbs. Torque in criss-cross pattern. On the axle nut I get it tight as hell then bang the tab in.
Old Jun 12, 2003 | 09:23 PM
STEV3-O's Avatar
Default Re: Clutch install question(b16) (Phat_Optimo)
on the helms its 87 lbf-ft for the flywheel my buddy just called me saying. whose right does it matter
Old Jun 13, 2003 | 02:45 AM
94CivicSi's Avatar
My Honda factory service manual says 76 ft/lbs.
Put some anti-seize on those axel nuts before you put them back on. It'll make your life a lot easier when you need to get them off again some day.
trooper0641
Nov 29, 2004 03:10 PM
JDM-97CX
Oct 23, 2004 01:56 PM
b18bVtecRS
Aug 24, 2004 03:42 PM
Ben18C
Apr 21, 2004 03:06 PM
