Clutch Install - need tranny jack
So I'm putting in the exedy/toda and need a friggin' tranny jack.
anyone know of places to rent one? I don't want to shell out $$ to go buy one...
I tried Pepboys, Autozone, Napa and no luck...
Just use a friend (if you have one) its a lot cheaper than renting or buying a tranny jack. Either that or just have the friend put a normal jack under it while you pull the tranny off the dowels. Then he moves the jack and you set the tranny on the ground.
yeah the easiest is always using a floor jack with a block of wood but its always quicker to have a big friend bench press the tranny into position. :D i do it all the time takes umm less than 5 seconds...
how tough is a clutch install with just removing the tranny? any time estimates? just remove axles,drain tranny fluid, drop tranny, install clutch,and then all those in reverse order again? need to put my action clutch in, or i can have it done for 120.
Timewise, it depends how mechanically inclined you are and how much experience you have on integras. I did mine in 3 hours with a friend. My brother just took like 8 hours just getting the tranny out (he ran into multiple problems). It all depends what you run into and how much you know.
well, its different if its two scrawny asian guys...
a 300lb tranny is pretty heavy to me, lol. But the jack/wood block should do the trick. Thanks for the info guys...
however, I didn't account for various little parts that need be replaced(slackerness + beer + strip club). I hear some clips and bushings need replacement when doing a clutch and the dealer closed an hr ago. I have to wait til Monday. Friggin' a.
anyone mind putting together a list of what little odds and ends need to be replaced?
[Modified by gsrmunj, 1:14 PM 3/15/2003]
a 300lb tranny is pretty heavy to me, lol. But the jack/wood block should do the trick. Thanks for the info guys...however, I didn't account for various little parts that need be replaced(slackerness + beer + strip club). I hear some clips and bushings need replacement when doing a clutch and the dealer closed an hr ago. I have to wait til Monday. Friggin' a.
I think a tranny only weighs like 80-100lbs, most people can probably bench at least that much.
a 300lb tranny
a 300lb tranny [Modified by gsrmunj, 1:14 PM 3/15/2003]
Go to http://www.c-speedracing.com click on howto and see their clutch install guide.
I believe http://www.bseries.net might also have one, and try http://www.team-integra.net articles.
a 300lb tranny
Doesn't weight close to 300 lbs. TRy 80lbs.
I believe http://www.bseries.net</a> might also have one, and try <A HREF="http://www.team-integra.net" TARGET="_blank">http://www.team-integra.net articles.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bseriesy0 »</TD></TR><TR><TD CLASS="quote">A tranny jack
do they make one? Ive never seen one.
I use a regular jack
i was thinking the same thing until i went to Pepboys the other day and saw one
do they make one? Ive never seen one.I use a regular jack
</TD></TR></TABLE>i was thinking the same thing until i went to Pepboys the other day and saw one
b18c trannys run about 60ish pounds...believe me im not all that strong and i benched an h22 up with my freind pulling it from up top too...its not all that hard, but just make sure you take all the harness etc of the firewall where youll bump the tranny into them putting it back up....for a $120 id have them do it...less work for me = better...but then again ifits going to get done right...its going to get done by me!
OBDII Integra
Sep 11, 2009 08:56 PM
Sam92Teg
Aug 14, 2005 08:05 PM
