clogged cat
Old Jul 22, 2003 | 05:37 PM
eknine's Avatar
Default clogged cat
has anyone had this problem? can you describe the effects?
Old Jul 22, 2003 | 06:49 PM
Mohudsolo's Avatar
Default Re: clogged cat (eknine)
Engine runs OK at low speed and throttle, but has no top end and poor response. May sound odd at full throttle. Pull the bolts at the downpipe to converter flange and look at the front of the converter. The "grid" should be all open holes with none plugged and no melting. It's also possible to measure using a pressure guage if there is a fitting to attach to the exhaust manifold. Sometimes the catalyst in the converter will break apart in which case it may rattle.
They can clog if the engine is run too rich. They melt when overheated. Breaking apart seems to be a combo of bad luck and maybe poor design/manufacture.
925EKCOUPE
10
Jun 22, 2009 05:18 PM
thunderlips
Jan 9, 2009 01:39 PM
itr_henrik
Feb 28, 2007 02:14 PM
t0ekn3e
Nov 6, 2004 11:49 PM
ITSUKA
Aug 4, 2004 09:03 PM
