cleaning valves with a wire wheel . ok or no?
Old Jul 1, 2006 | 02:46 PM
97grnrs's Avatar
Default cleaning valves with a wire wheel . ok or no?
i have some spare ls valves i wanna clean up. would a shop grinder/ wire wheel work to clean them witout removing the metal or no? if not what would work to take off carbon
Old Jul 1, 2006 | 02:53 PM
green91's Avatar
Wire wheel is fine to clean them up, just try to clean the face and not around the edge or you can get them out of round.
Old Jul 1, 2006 | 03:59 PM
97grnrs's Avatar
Default Re: (green91)
what if there is carbon on the stem/edge part
Old Jul 1, 2006 | 04:12 PM
jdmrhdtt's Avatar
Default Re: cleaning valves with a wire wheel . ok or no? (97grnrs)
Carbon build up raises compression!!!!!!!
Old Jul 3, 2006 | 05:16 PM
nu_B's Avatar
Default Re: cleaning valves with a wire wheel . ok or no? (jdmrhdtt)
I would use a softer (hand) wire brush for the stem part. I don't think the carbon build up on the stem matters that much, Mind you, my reference for this is rebuilding heads for chevy 350ci motors, not honda motors . Im not sure if it is much more critical for that area to be clean on ohc motors. And correct me if wrong, but isn't it better to have carbon on the pistons than the valves to increase compression?
I hope i helped a bit!
Old Jul 4, 2006 | 01:14 PM
PURPLETERROR aka BIGMATT's Avatar
Wire wheel all that garbage off, youe arent goin to hurt anything, carbon buildup on the stems and the backside of te valves decreases flow. Just get a good grip in the valve, its easy to shoot one across the room
Old Jul 4, 2006 | 01:52 PM
Flashmn's Avatar
Default Re: cleaning valves with a wire wheel . ok or no? (PURPLETERROR aka BIGMATT)
Yeah, it slips out of hands VERY fast
raverx3m
Feb 23, 2014 05:21 PM
ozh_hawaiian
Jul 18, 2010 04:24 PM
97grnrs
Sep 30, 2007 05:00 PM
dave@passenger
Welding / Fabrication
Nov 7, 2006 08:33 AM
No-Gi
Feb 8, 2005 05:37 AM
