civic wont start
Old Apr 29, 2009 | 06:23 AM
malink's Avatar
Default civic wont start
hi,
My car has been running fine and was starting with no issues till today.
#1 the starter doesnt crank
#2 the fuel pump doesnt prime gaz when the key is on
#3 normally, when you put the key at on, the check engine light comes up for 3-4 seconds but not anymore
I did change the main relay with one of my spares and still there...
any help?
Old Apr 29, 2009 | 06:37 AM
kyden's Avatar
Default Re: civic wont start
do any lights come on? you might have a bad ignition switch.
Old Apr 29, 2009 | 06:44 AM
malink's Avatar
bad grounds
now everything works i think there is a short somewhere in the engine bay
Old Apr 29, 2009 | 06:54 AM
92_civic's Avatar
check your ground at the tstat housing
Old Apr 29, 2009 | 07:09 AM
malink's Avatar
problem solved
Old Apr 30, 2009 | 08:53 AM
92_civic's Avatar
what was it
Old Apr 30, 2009 | 06:08 PM
gt35rSI's Avatar
Originally Posted by malink
problem solved
having the same issue what was it....
Old Apr 30, 2009 | 07:57 PM
malink's Avatar
took off all the grounds...clean and used sand paper to remove any sort of contamination on the grounds and body. Reconnect everything and voila
xxOldschoolxx
12
Mar 23, 2013 05:38 PM
osbunjosh
12
Mar 3, 2013 12:20 PM
lazylegs15
Sep 14, 2008 10:20 PM
taboo948
May 19, 2008 07:26 AM
messeduprex
Feb 8, 2006 10:17 PM
