Civic Cold Inrake
Old Aug 14, 2002 | 06:24 PM
MiamiFlorida's Avatar
Default Civic Cold Intake
I just installed a AEM short ram intake to my D16y7 with an Automatic Transmission. I was told this will gain HP but sometimes it feels like it looses power, like if the intake doesn't have pressure. Is this normal? Is there something I need to adjust to fix this?
[Modified by MiamiFlorida, 3:25 AM 8/15/2002]
Old Aug 15, 2002 | 08:59 AM
Default Re: Civic Cold Intake (MiamiFlorida)
Anyone?
Old Aug 15, 2002 | 09:13 AM
Spade's Avatar
Intakes don't provide that much power......and are pretty damn hard to install wrong. actually I don't think you can.
Old Aug 15, 2002 | 09:38 AM
sohc_boy's Avatar
your car feels slower cause u lost some of your low end and since u have an auto low end helps alot.
Old Aug 15, 2002 | 03:07 PM
Default Re: Civic Cold Intake (sohc_boy)
So what do you guys recommend? I'm also thinking of installing a header. You think this will improve?
Thanks
[Modified by MiamiFlorida, 12:08 AM 8/16/2002]
Old Aug 15, 2002 | 03:31 PM
VTECorona's Avatar
I'm suprised you don't feel the slightest difference, there really is no way to screw up a intake install. Do you atleast hear a roar coming from your motor now?
Old Aug 15, 2002 | 04:01 PM
innate's Avatar
when does the car feel like it's losing power?
Old Aug 15, 2002 | 04:05 PM
TONEBONE's Avatar
Did you reset the ecu?
Old Aug 15, 2002 | 05:36 PM
Default Re: Civic Cold Intake (innate)
When I'm running about 30 mph and I try to down shift the auto trans to pass a car. That's when it has no power. I have to depress the pedal a lot in order to down shift. It also makes a deep goar sound. It wasn't doing this when I had it stock. A friend told me I had to adjust something in the throttle. Is this right?
Why do I have to reset the ECU?
Thanks for your replies.
MF
Old Aug 15, 2002 | 07:24 PM
acuratech's Avatar
its probably performing the same, it just seems slower from the noise, something about that noise that makes it seem slower, the roaring noise is normal, just make sure the clamps are tight, and everything is on properly, especially the intake air temp. sensor. dont adjust anything on the throttle, hope this helps
Old Aug 15, 2002 | 11:14 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
why downshift? just stamp on the pedal. it'll downshift for you.
crazyskater510
61
Dec 31, 2012 09:32 AM
ultimatecivictyper
Oct 28, 2006 08:21 PM
johnRsX05
Jan 2, 2005 07:45 AM
H22EKHATCH
Sep 7, 2004 11:03 AM
LuderX
Oct 24, 2002 06:03 PM
