Chipped P28 ECU-Solid Cel
Old Sep 20, 2004 | 03:45 AM
civic-4-ges's Avatar
Default Chipped P28 ECU-Solid Cel
I recently chipped my ecu, with the guide from Keebler65's Uberdata page. Now that I am complete I burned a p28 basemap and got the ecu into the car this weekend. The ecu has a datalogging port added to it, the same as described on Keebler65's page.
I plugged in the ecu into my 98 civic lx w/d16y8 and now I get a cel. Before this I had my obd2-1 harness spliced for my apexi VAFC. I have since removed the VAFC and repaired the splices with soldered joints. I double checked all my connections and all wires seem to be correct (I didn't **** that up I think).
When I plugged in the ecu, I get a constant cel. Not quite sure why. I cut the jumper located at J1, and still, constant cel.
Anyone have any ideas why?
Old Sep 20, 2004 | 04:56 AM
variablevalve's Avatar
Default Re: Chipped P28 ECU-Solid Cel (civic-4-ges)
wow, i really wish i could understand that. Where did you learn about all this ECU mumbo jumbo... is there an newbie guide somewhere I can read? lol
Old Sep 20, 2004 | 05:05 AM
Default Re: Chipped P28 ECU-Solid Cel (variablevalve)
http://home.mn.rr.com/keebler65/honda/
^^ Good Start
Old Sep 20, 2004 | 07:14 AM
R-Toyz.com's Avatar
You mentioned adding the datalogging port to the ECU...was that done correctly? Cutting the J1 will more than often cure an issue related to chipping or a bad chip, but since that didnt work you might want to check the port you added. Take the datalogging port out and plug the whole ECU in....if that throws a solid CEL then the ECU is fried
Old Sep 20, 2004 | 07:15 AM
Default Re: Chipped P28 ECU-Solid Cel (rtzcom)
Not what I wanted to hear, but it could be a problem. Especially since the stock chip is not looking for that port at all.
Thanks for the idea!
Old Sep 20, 2004 | 05:34 PM
TTT
Old Sep 21, 2004 | 08:22 AM
Old Sep 29, 2004 | 07:33 AM
R-Toyz.com's Avatar
no luck? try putting in another ecu in your car and see how that goes
Old Sep 29, 2004 | 07:34 AM
Default Re: (rtzcom)
Fixed it, bad soldering
Old Sep 29, 2004 | 07:36 AM
R-Toyz.com's Avatar
Default Re: (civic-4-ges)
good! have fun!
B20Luder
Engine Management and Tuning
Aug 1, 2010 04:14 PM
CHEFH22HATCH
Aug 30, 2007 10:05 AM
drshottest718
May 22, 2006 04:31 PM
Mr.Death
Jul 9, 2005 06:50 PM
