Chip maps
Ok I have a 91 Civic SI with a D16Y8 going in it. I rebuilt it with 10.5:1 c/r JE's, eagle rods, port and polished Y8 head, DC header, ram air intake, and catback exhaust. v-tec engagement is going to be about 4500 rpm.
Well I am still running a PM6 ecu and will need a chip for it. The guy I know on here usually deals with turbo and has no idea how to burn a chip for this setup besides just a regualar Y8 base map. Does anyone have a map for this setup or can make one? Thanks a lot! Doug
What are you looking to use for VTEC fuel and timing maps? You might want to look at http://www.pgmfi.org for the PM6 one wire VTEC solution.
I would tell the guy you are having burn the chip for you just burn a P30 maybe even a p72 map and then you both could tune from there. I use Uberdata(OBD1) or else I would make a map for you.
Phil
Phil
Civicman86
Mar 24, 2007 01:15 PM
