check engine light reads o2
Old Dec 22, 2005 | 09:45 PM
SLR ef9's Avatar
Default check engine light reads o2
just finished swap into 91 std hatchback and ecu reads o2 check engine i replace the old one with a new aftermarket one could that be the problem
Old Dec 22, 2005 | 11:35 PM
ekb16's Avatar
did you already replace it??
Old Dec 23, 2005 | 07:17 AM
SLR ef9's Avatar
Default Re: (ekb16)
yea it's a bosh o2 sensor could that be the problem
Old Dec 23, 2005 | 01:07 PM
Perfectionist's Avatar
Default Re: (SLR ef9)
In my experience, the ECU won't set a code for the O2 sensor too quickly. You could drive for months with a malfunctioning slow and lazy sensor and the ECU wouldn't care as long as it sees something. I would check the wiring connection(s). A hard failure like that will definately set a code.
BTW, I've had poor results using the Bosch generics. Just my experience though.
Old Dec 23, 2005 | 06:14 PM
puffsef's Avatar
Default Re: check engine light reads o2 (SLR ef9)
Make sure the wiring is right if it is a universal one.
sakasaku
14
Oct 20, 2009 03:27 PM
92_b20_eg
Mar 7, 2008 10:38 PM
the_0ne
Jul 16, 2006 08:01 PM
Koyoloeor
Oct 13, 2005 04:57 PM
allmotorsi04
Dec 6, 2003 03:08 PM
