Check engine light came on
Old Jun 8, 2002 | 10:26 PM
InevitableRace's Avatar
Default Check engine light came on
well i was running my car.at high rpms and the light came on it is flashing 9.and i looked in the book and it tells me No.1 cylinder position (CYP)..what the **** is that....then it tells me......this sencer,used on OBD II models,produces a signal which the ECM/PCM uses to identify number 1 cylinder and to time the sequential fuel injection and ignition...if that is for the OBD2 ecu witch i dont have i have a 94 gsr with a chiped p28 OBD1 and if it is for me were the hell is the sencer?..... thanks Ross.
Old Jun 9, 2002 | 05:53 AM
Chiovnidca's Avatar
Default Re: Check engine light came on (allmotrb18c1)
[QUOTE] were the hell is the sencer?QUOTE]
It's in the distributor.
Old Jun 9, 2002 | 09:10 AM
WOW it over 20 people to look at this post and 1 person answered thats good thanks i kinda new where it was i just needed to know my self.so it looks like im going to Acura for a new distributer.thanks again...
Old Jun 9, 2002 | 06:03 PM
Roger's Avatar
Everybody knows that buying parts from the dealer is gonna cost some bank. Its expensive and convienent if they have the part in stock. But, if you have time and patience, you can order OEM acura parts at this website:
http://www.acuraautomotiveparts.net/...p/mws/home.htm
I order all my acura parts here. They are quick and the prices are alot lower then the dealer prices. If your acura dealer has the distributer in stock, and you really need it, then cool, get it. But if you want to save some money, order it here. Hope this helps.
Old Jun 10, 2002 | 04:23 PM
thanks for the help
Old Jun 10, 2002 | 04:31 PM
minime's Avatar
i would help you but you already know the answer. by the way that code is obd1.
hothondas
Aug 4, 2008 06:24 PM
OMGBBQTEHWTFDOOD
Oct 19, 2007 10:18 AM
1bar
Aug 9, 2003 09:49 PM
1bar
Apr 19, 2003 09:08 PM
BMacls
Mar 18, 2003 08:29 AM
