Check Engine Light..?
Old May 15, 2003 | 01:28 PM
10K2HVN's Avatar
Default Check Engine Light..?
Hello,
i was wondering what it means when my "Check Engine" light turns on (right when i turn on the car) then flashes 10 times...??? Can anyone help? Thanks for any...
-10k
Old May 15, 2003 | 01:36 PM
Chiovnidca's Avatar
Default Re: Check Engine Light..? (10K2HVN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 10K2HVN &raquo;</TD></TR><TR><TD CLASS="quote">Hello,
-10k</TD></TR></TABLE>
Does it run rough when it's flashing? Have you checked for codes?
Old May 15, 2003 | 01:43 PM
10K2HVN's Avatar
Default Re: Check Engine Light..? (Chiovnidca)
..car runs fine..light isnt on after the 10 flashes.. although recently, when the car is cold, it has a little loop in the idle. ill go fine a wire and try to check...
Thanks.
Old May 15, 2003 | 01:54 PM
10K2HVN's Avatar
k, its
1 long flash
10 short flashes
EDIT: i got it~! Thanks for your help!
Old May 15, 2003 | 02:57 PM
apexi's Avatar
10 is Intake Air Temp That sensor is on your intake check it for 5 V and ground.
clsmooth135
Jun 3, 2007 05:16 PM
SlammedBlackGSR
Nov 20, 2006 02:04 PM
Yak BallZ
10
Jul 25, 2005 10:05 PM
redludevtec
Aug 15, 2004 04:00 PM
kamdog
Jan 5, 2003 05:48 PM
