Check engine light???
Old Apr 27, 2003 | 05:50 PM
AzDrag1's Avatar
Default Check engine light???
Im having a problem with a check engine light. Its an OBDI setup. When I jump the wire and get the code the first flash is a very dim flash. Its only visible when its dark. Then 5 more flashes follow that one. I was thinking that would be a total of 6 flashes. I checked the CTS and cant get much of an ohm reading either. Also the wires leading to the CTS have an average of 12 volts. I though there was only suppose to be 5. Anyone know or had this problem either? Anything I can do to fix it. Ive thrown 3 different CTS's in there but nothing seems to work.
I was also contemplating the fact that it could be a map sensor failure with 5 blinks and the first one being a "setup" blink. The map sensor thats in there is from a 91' or so CRX but everything fit up.
Any help would be greatly appreciated.
eg2tr
Jan 5, 2008 09:36 PM
MIZIKETSK
Jun 15, 2004 06:36 AM
BeanRacer
Nov 24, 2001 11:15 AM
