check engine light
Old Mar 22, 2002 | 12:26 AM
98teg's Avatar
Default check engine light
what happens to the car when the check engine light coms on, on a gs-r. Does it run rich, does vtec engage? also is it bad drive the car when the C.E.L is on?
Old Mar 22, 2002 | 05:53 AM
speedillusion's Avatar
New User
Default Re: check engine light (98teg)
c-speedracing.com
has the info u need... hope that helps.
Old Mar 22, 2002 | 10:13 AM
Kataku2K3's Avatar
Default Re: check engine light (midnitekreeper)
It's really fine to drive your car it just runs the ECU in safe mode. Short the jumper above the ECU to find the code you are throwing. When you figure that out you'll know what needs to be fixed hopefully. Hope this helps
Old Mar 22, 2002 | 11:08 AM
ATurboCivic2NV's Avatar
Default Re: check engine light (JDMspecEG6)
when you run boost with out a check valve on the map sensor i wil run like ****. i could get out of my car and almost push it faster. i dont know for sure but i think it all depends on what the problem will depend if it goes into safe mode or not.
kaoss_11
Sep 10, 2006 04:14 PM
oneoffaccord
Sep 9, 2006 09:21 AM
CaliRockrr
Nov 26, 2005 04:37 PM
low430
Aug 28, 2005 06:31 PM
0-400DC2-R
Sep 28, 2003 11:48 AM
