CHECK ENG LIGHT
I have a 2000 1.8 ls non v-tec with a check eng light that keeps coming up for misfire on all 4 cyl. I have checked everything I can think of and yet after 5 to 10 miles it keeps coming back.
I put in an msd dist, new plugs, wires, cap rotor, and reste the timing.
Any ideas?
Any ideas?
A flashing cel indicates a pretty bad missfire. I've never seen one code all 4 cylinders with a flashing light.
Any mods done to the engine? Is it a swap? What ecu? Has it been tuned?
new ecu 2 months ago(factory)
header,venom 400, cat back exhaust, msd ignition, skunk2 intake, and 72 mm throttle body.
it started about three months after all the upgrades with bad cam sensor so i replaced the dist. after that i started to get the misfire code. car runs great, that is why i can not figure this out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jerry05 »</TD></TR><TR><TD CLASS="quote"> replaced the dist. after that i started to get the misfire code. </TD></TR></TABLE>
Something with the distributor maybe?
freddysEF
43
Jan 29, 2008 12:41 PM
