changing sub frame, how do I remove this?
Old Nov 5, 2003 | 12:10 PM
FastNFurious
Guest
Posts: n/a
Default changing sub frame, how do I remove this?
I trying to swap out my sub frame but the "steering thing"(circled in white) is in the way..
I took off all the bolts that hold it up but the steering shaft or whatever is still connected... How do I free it? do I have to take off the thing I circled in yellow or what?? thanks...
Old Nov 5, 2003 | 12:18 PM
b20turbojason's Avatar
Default Re: changing sub frame, how do I remove this? (David555)
that steering thing is a rack n pinon. if you un bolt it from the sub frame you can pull it down enough to see the steering colomn. there is a streering knuckle that has a 10 mm bolt. that will disconnect the rack.
Old Nov 5, 2003 | 12:25 PM
FastNFurious
Guest
Posts: n/a
so, I don't need to mess with the thing circled in yellow? I just have to tug it down a little and disconnect it with a wrench..
thanks
c_logoteg01
Jun 29, 2015 04:28 AM
Pvt Fields
Mar 31, 2008 01:59 PM
i-want-a-crx
Nov 23, 2007 04:03 AM
Sean EH2
Jul 31, 2003 04:35 PM
