Changing antifreeze
I need to change my anti-freeze and the owner's manual says to "remove the drain bolt from the cylinder block". Where is this located? How much anti-freeze will I leave in if I don't remove the drain bolt? I have a '99 CRV.
Thanks for the suggestion, but you're not talking to an expert mechanic here. I don't know where the engine id is located. How much anit-freeze will drain out after removing this bolt?
See if it's here:
http://www.bseries.net/images/garage...ermostat03.jpg
Koko4
16
Dec 25, 2013 05:42 PM
Monty
Jul 23, 2002 03:56 AM
