changed my mind abouit the zc
Old Aug 14, 2002 | 05:48 PM
cr-x si's Avatar
Default changed my mind abouit the zc
Up untill yesterday i was set on getting a zc engine for my car. But i decided not to. Even after saving up all the $$. Cause there is know one i trust working on my car around here. and everyone i have talked to said they had a lot of trouble getting there zc to run right (wiring probloms)
So what i am going to do with the money is durn my 1.6 sohc engine into a monster. i plan to bore it out, put in new pistons,rings,valves,springs,and cam. Then put on some nice bolt ons. Like a fuel rail,injectors,cam gear. headers.
With that stuff i should get just as much power that i would get with a zc.
How much of an overbore should i go on my cylinders??
any of you guys have an estimenton what it would cost for just, an over bore, new pistons,rings,valves,springs,and a cam. My budget is about $1500
Old Aug 15, 2002 | 12:55 AM
D16Z6racing's Avatar
Default Re: changed my mind abouit the zc (cr-x si)
You're gonna need more than $1500. That just might cover a port and polsish at some shops.
Why not juice it? 55 shot?
You might be able to get a Gude Head Package. http://www.ardperformance.com
I'd save a little more and try to do it all at once IMO.
Old Aug 15, 2002 | 02:08 AM
kinesistech's Avatar
If you have a crx si then you should just buy a y7 head. It will raise compression and it has 1mm bigger valves on both sides. It fits the everything on the engine perfectly. There will be no down time, and you'll be impressed with the results. Buy one of those heads, a cam, and cam gear. You should have more than enough.
Old Aug 15, 2002 | 11:11 AM
cr-x si's Avatar
Default Re: changed my mind abouit the zc (kinesistech)
i live in medina county, in ohio 40 miles south of cleveland
and i am burning oil so i need new pistons know matter what.
[Modified by cr-x si, 8:19 PM 8/15/2002]
Old Aug 16, 2002 | 12:23 AM
Great, use pistons from an a1 or zc. 1st gen integ 86-89. You'll have even higher compression.
90dohczccrx
Oct 11, 2010 05:04 PM
Jdm94siR
Apr 30, 2007 05:10 PM
slocrxsi
11
Dec 2, 2003 05:39 AM
Si_Power
Jul 12, 2003 10:15 PM
cr-x si
27
Aug 18, 2002 10:06 AM
