Cel issue!!!!!
Old Dec 23, 2008 | 10:41 AM
Civic89stdB16's Avatar
Default Cel issue!!!!!
I have a jdm b16 in a 89 hatch thats obd1. Its throughing codes 12 and 41 with a jdm p30 b16 ecu. please help me. im going to take care of the code 41 with a new o2. Someone help me with the code 12. please help me out. BTW The ecu is stock. thank
Old Dec 23, 2008 | 04:58 PM
Default Re: Cel issue!!!!!
someone help me
Old Dec 25, 2008 | 04:08 PM
mouab18c1's Avatar
do you know what each code is referring too?
Old Dec 25, 2008 | 04:57 PM
yes code 12 is the egr lift sensor which i dont have on a b16. The code 41 is the primary o2 sensor and its been fixed. so i just have to get rid of the code 12. thanks
Old Dec 25, 2008 | 08:12 PM
mouab18c1's Avatar
if your motor dont have it then its reading off of your ecu..is it chipped? trying crossing it off
Old Dec 25, 2008 | 08:54 PM
the ecu is stock obd1 p30 and it doesn't even have a wire going into port a 11 on the obd1 side of the jumper harness. i don't know how this could be sending the code 12 which is for the egr selonoid valve. please help me.
Old Dec 27, 2008 | 12:48 PM
mouab18c1's Avatar
hmm thats wierd because your running a jdm ecu with jdm motor....try using a usdm b16 ecu...ill do some research also
Old Dec 27, 2008 | 01:55 PM
mouab18c1's Avatar
this is weird because i've never seen a EGR solenoid on b series...are you sure thats a b16 ecu? well not any b series obd1 or obd2 cars...check this page out...could help out a bit...cuz if it doesnt show up when using the gsr ecu then im thinking your using an obd0 ecu...http://hondaswap.com/hybrid-eg-ek-dc...wiring-142906/
Old Dec 27, 2008 | 02:04 PM
mouab18c1's Avatar
isnt 89 obd0? that could be your problem
Old Dec 27, 2008 | 02:21 PM
mouab18c1's Avatar
https://honda-tech.com/forums/showth...2122763...read this thread....i got bored so researched for you..hopefully it will help you somehow...
h22integra.eire
Engine Management and Tuning
Sep 14, 2015 06:08 PM
Civic89stdB16
Dec 24, 2008 10:25 AM
Endoe
Dec 30, 2004 01:35 AM
vtec fan
Feb 3, 2004 10:48 AM
JDMjdawg
Dec 8, 2003 03:13 PM
