cel and ect question
Old Sep 23, 2002 | 03:11 PM
Kataku2K3's Avatar
Default cel and ect question
What is a non OBD code 15??? Is it the same as OBD1 just as many of the other codes? Also i hooked up a GSR block in my friends 88 CRX cuz his thrust washers went out in the B16 destroying the bottom end. My question is, i rewired the engine coolant temperature switch that the B16A has on the back of the block so that we could plug it into the GSR's ECTS that's comes on the thermostat housing, is there any problems with this or should it be fine.. Thanks in advance.
Old Sep 24, 2002 | 06:56 AM
Kataku2K3's Avatar
Default Re: cel and ect question (JDMspecEG6)
I know someone knows this......
Old Sep 24, 2002 | 09:38 AM
sgT's Avatar
sgT
all codes are pretty much same for all years
http://sgt.ghettoracer.com/dtc.txt
FYI, thats not an ECT on the thermostat housing.
That is the fan switch.
The ECT is on the side of the head.
I think the old B16/B18 motors have 2 ECTs one on the head and one on the block
Old Sep 24, 2002 | 02:34 PM
Kataku2K3's Avatar
Default Re: cel and ect question (sgT)
yea i know, the ECTS is the switch for the fan, but what i am saying is if you have the old non OBD wiring set up for the switch on the back of the block can you simply rewire it so that it plugs onto the thermostat housing??? Thanks
Old Sep 24, 2002 | 10:01 PM
Kataku2K3's Avatar
sgT can you please help me out cuz i know you probably know, i just wanna make sure i wired it correctly.... Thanks
Old Sep 24, 2002 | 10:19 PM
tinkerbell's Avatar
pretty sure you can, are both sensors two pin?
if yes, just change it over.
it is just a 'normally open' switch that closes once a certain temp is reached.
HTH,
t..
Old Sep 25, 2002 | 07:42 PM
Kataku2K3's Avatar
Default Re: cel and ect question (tinkerbell)
Thanks man, that's all i needed to hear...
builtsinglecam
Jun 2, 2010 11:07 AM
1320king
Jul 27, 2009 12:05 AM
BeniRacing
Jun 30, 2007 06:40 PM
solohatch
Aug 8, 2005 06:43 AM
