CEL Code 67 popping up - catalyst system
Old Aug 25, 2004 | 01:46 PM
Phelixthecat's Avatar
Default CEL Code 67 popping up - catalyst system
this is a 98 cr-v. this is what has happened/been done to the vehicle recently:
removed and re-installed header (possibly damaged o2 sensor? o2 sensors have their own codes though)
ran out of gas on a highway - refueled with 92 gas and started driving worse for some reason - started feeling better right after adding 87 gas.
what could this be?
Old Aug 25, 2004 | 02:24 PM
XiiiXiii's Avatar
Default Re: CEL Code 67 popping up - catalyst system (Phelixthecat)
i believe 67 is the code that your polluting more than tolerable levels. I had that code thrown when I had a racing cat on my car. Its not going to kill you. Just reset your ecu, and see if it comes back on again. If it does you either have a bad o2, or your cat is not working anymore.
Old Aug 25, 2004 | 05:29 PM
type-t's Avatar
Default Re: CEL Code 67 popping up - catalyst system (XiiiXiii)
how do you reset the ecu?
Old Aug 25, 2004 | 09:13 PM
AutoWerks's Avatar
Default Re: CEL Code 67 popping up - catalyst system (type-t)
take out the 15amp ecu fues under the hood out for 15 mins
Old Aug 26, 2004 | 03:49 PM
Default Re: CEL Code 67 popping up - catalyst system (AutoWerks)
i thought it was the 15 and the 7.5 next to it? anyways, that's what i did, and the code hasn't come back yet.
GEIJIN
Aug 7, 2009 07:56 PM
DJ Gurgla GSR
May 30, 2006 12:50 PM
DarkBB4
Aug 27, 2005 09:31 AM
BigBoyJohn
Dec 26, 2003 11:35 AM
