CEL code 20...
I know its Electrical Load Detector circuit, but I want to know what kind of problems are associated with this circuit going bad, and do I need to get this from Honda or can I get it from any auto parts store?
I had a code 20 CEL due to an unplugged knock sensor...So the first thing you need to do is check all of you sensors...you may not have one hooked up or bad circuit. Also check your grounds.
You sure you didn't have a code 23... I really don't see how you fixed an ELD code by plugging in your KS.. The ELD is located inside the main fuse box under the hood... Peace
http://www.hondata they had something in the forums
The ELD wire to the ecu.....
They took 2 Resistors one from ELD to 5v and another from eld to ground.
So that the ELD would get 2.5 volts.....
