cel code 16
Old Jan 8, 2006 | 08:52 PM
  #26
Bigblockhatch's Avatar
Default Re: (error)
looks like u have the tps-plug pluged into the MAP sensor
Old Jan 8, 2006 | 09:11 PM
  #27
error's Avatar
Default Re: (Bigblockhatch)
so the tps sensor is in the back, and the MAP is on the top of the throttle body? hmmmm. well, im missing one or the other.
Old Jan 9, 2006 | 05:08 PM
  #28
Katman's Avatar
Default Re: (error)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by error &raquo;</TD></TR><TR><TD CLASS="quote">so the tps sensor is in the back, and the MAP is on the top of the throttle body? hmmmm. well, im missing one or the other. </TD></TR></TABLE>
that is correct...
its easy to mix up the TPS & MAP sensor plugs as they both use the same style of plug.
TPS on backside of TB and MAP is on top of the TB...
Old Jan 9, 2006 | 06:02 PM
  #29
error's Avatar
Default Re: (Katman)
the dx harness is not plug and play. i found this out the hard way. map sensor id on the firewall rather than the harness
Old Jan 9, 2006 | 06:39 PM
  #30
99CivicSiBrian's Avatar
B A N N E D
Default Re: (error)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by error &raquo;</TD></TR><TR><TD CLASS="quote">the dx harness is not plug and play. i found this out the hard way. map sensor id on the firewall rather than the harness</TD></TR></TABLE>
Yes what you said here, I have found to be correct also.
B
Old Jan 9, 2006 | 10:32 PM
  #31
Katman's Avatar
Default Re: (error)
it doesn't matter if the MAP is firewall mounted, it will still plug to the harness. Just dismount the MAP sensor from the firewall and let it dangle from the vaccuum tube leading to the TB...no biggy
here's some info on how to convert a CX 1-wire 02 sensor to a 4-wire 02:
http://www.hondaswap.com/forum...33248
Modified by Katman at 1:09 AM 1/10/2006
Old Jan 10, 2006 | 10:54 AM
  #32
error's Avatar
ok, so the guy in the link is wiring directly to the ecu?
Old Jan 11, 2006 | 11:42 AM
  #33
Katman's Avatar
Default Re: (error)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by error &raquo;</TD></TR><TR><TD CLASS="quote">ok, so the guy in the link is wiring directly to the ecu?</TD></TR></TABLE>
huh?
I'm betting someone cut the MAP sensor plug off the harness. Have you checked to see if there's wiring (near the TPS wiring) that looks like a plug has been cut off from the harness?
Old Jan 11, 2006 | 12:37 PM
  #34
error's Avatar
the dx map sensor plug is on the firewall
SolScifen
May 19, 2013 11:35 AM
LivinDreamsEK9
Mar 27, 2007 06:22 PM
THEUSED
Apr 16, 2006 10:18 AM
2camsaam
Jun 12, 2003 09:33 AM
