Catcams Camshaft Question?
I found this http://www.hondaswap.com/forum...13132
Thing is I bought Some Catcams Camshaft for my B16A Part # 2501613... I tought those were better cams then Type R ones.... here are the Spec...
http://www.catcams.be/
--------------------------------------INTAKE--------------------EXHAUST
-----------------------------------pri | sec | Vtec--------------pri | sec | Vtec
clearance----------[cl]-------------0.30mm----------------------0.30mm
duration-----[0.1mm+cl]-----228 | 228 | 266°-----------213 | 228 | 261°
duration-----[1.0mm+cl]-----194 | 194 | 234°-----------177 | 194 | 230°
valve lift--------[cl=0]-------8.10 | 8.10 | 11.00mm----5.20 | 8.10 | 9.95mm
cam lift------------------------5.40 | 5.40 | 6.90mm---- 3.60 | 5.40 | 6.35mm
peak angle--------------------101 | 101 | 96°-------------103 | 104 | 100°
timing-------[1.0mm+cl]--(-4/18 | -4/18 | 21/33°---(12/-15 | 21/-7 | 35/15°
lift at TDC-------[cl=0]------0.95 | 0.95 | 4.05mm------0.45 | 0.75 | 3.10mm
Could someone compare those cams to an other mark? cause after installing these cams, their were really a big difference over the B16a ones!... thanks
bfong13
Jun 26, 2005 06:32 AM
