Cat. 02 sensor used as primary?
Old Sep 24, 2003 | 11:39 AM
specie's Avatar
Default Cat. 02 sensor used as primary?
try the search but no results were yielded.
Is the cat. and primary 02 sensor identical in function. Can they be interchanged with no adverse effects? Thanks.
Old Sep 24, 2003 | 11:40 AM
specie's Avatar
Default Re: Cat. 02 sensor used as primary? (specie)
Oh yeah,
I don't think OBD1 and OBD2 sensors matter, but could anyone confirm this?
Old Sep 25, 2003 | 10:47 AM
specie's Avatar
maybe.
Old Sep 25, 2003 | 08:42 PM
salbaje's Avatar
yes i've used 2ndary o2's for primary
Old Sep 25, 2003 | 08:50 PM
HONDADNA's Avatar
Default Re: Cat. 02 sensor used as primary? (salbaje)
Yes! both secondar and primary serve the same function - they meassure o2 content in the exhaust stream. the only difference is length of the wiring that's all.
Old Sep 26, 2003 | 11:01 AM
Audi RS4's Avatar
Lover
Default Re: Cat. 02 sensor used as primary? (HONDADNA)
it does matter on an obdII ecu, because it reads before and after the cat, so it can adjust fuel. but as far as putting a OBDI ecu in it will just need the wires in the right pins.
Old Sep 26, 2003 | 11:36 AM
EE_Chris's Avatar
Default Re: Cat. 02 sensor used as primary? (AK1200)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDADNA &raquo;</TD></TR><TR><TD CLASS="quote">Yes! both secondary and primary serve the same function - they meassure o2 content in the exhaust stream. the only difference is length of the wiring that's all.</TD></TR></TABLE>
Lets clarify: They both OPERATE exactly the same, however, their purpose to the ECU is different.
You CAN use a secondary O2 in place of a primary, and vice-versa.
HONDADNA is correct.
Old Sep 26, 2003 | 11:42 AM
HONDADNA's Avatar
The main purpose of the secondary o2 is to monitor the cat operation.
all o2 sensor does one thing " MEASSURE o2 CONTENT IN THE EXHAUST"
The secondary o2 sensor does not switch from rich to lean unlike the primary does. The ECU monitor the how oxygen in the cat is using. A good operating cat will use all of the oxygen to properly convert gases.
while the primary o2 switch from rich to lean and this is want the ecu is looking at.
So, you can swap secondary and primary o2 sensor do exactly what the name stay. The only difference is the length of wires. and if you've got a four wire, three wire, or a singal wire.
The ecm don't if you swap primary to secondary it just wants to know how much oxygen is present.
6thgenva
Welding / Fabrication
Oct 14, 2010 07:11 AM
wudini
Sep 12, 2008 04:32 PM
AllSpedup04
Oct 10, 2005 01:52 PM
"Hites"
Feb 11, 2005 05:24 PM
2lobes1engine
11
May 11, 2004 03:14 PM
