Carbon Deposit on used pistons
Old Jun 30, 2003 | 10:12 AM
The Poopsmith's Avatar
Default Carbon Deposit on used pistons
I have a set of used JDM TypeR pistons and rods I want to drop into my GSR. They look like this
What should I do to take off the carbon deposit? Is it safe to spray it w/ brake cleaner?
Old Jun 30, 2003 | 10:52 AM
Ivan's Avatar
senior gold member
Default Re: Carbon Deposit on used pistons (DeeSeeToo)
yup brake cleaner will be fine.
Old Jun 30, 2003 | 10:56 AM
Blaze45's Avatar
Brrraaaap!
Default Re: Carbon Deposit on used pistons (Ivan)
Be sure to debur it while you have em out.
Blaze
Old Jun 30, 2003 | 11:07 AM
Default Re: Carbon Deposit on used pistons (Blaze45)
debur? what is that?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">Be sure to debur it while you have em out.
Blaze</TD></TR></TABLE>
Old Jul 1, 2003 | 06:27 AM
ap
Old Jul 1, 2003 | 09:23 AM
struppi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeeSeeToo &raquo;</TD></TR><TR><TD CLASS="quote">debur? what is that?</TD></TR></TABLE>
I think he means smoothing down the edges of the top of the piston or thin and portruding metal on the surface. Thin metal at the edge or surface of the piston gets hotter and these hot spots could lead to premature detonation.
This is just my understanding, somebody please verify.
Old Jul 1, 2003 | 10:46 AM
Blaze45's Avatar
Brrraaaap!
Default Re: Carbon Deposit on used pistons (riversideguy)
Sorry that I didnt get back to ya, I was searchin cause there was a DIY post on it and I was trying to find it for ya. I couldnt tho. Basically thats what it is. You get a real fine grit sandpaper and sand down sharp edges that could result in pre ig./deatonation if heated up.
Blaze
Old Jul 2, 2003 | 10:57 AM
thanks for the info. Just to be sure, could I "debur" the pistons I have myself, or is it the job of a machine shop?
Old Jul 2, 2003 | 02:48 PM
Propulsion's Avatar
do it your self, just dont get too carried away...
Old Jul 2, 2003 | 10:20 PM
martini's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">Sorry that I didnt get back to ya, I was searchin cause there was a DIY post on it and I was trying to find it for ya. I couldnt tho. Basically thats what it is. You get a real fine grit sandpaper and sand down sharp edges that could result in pre ig./deatonation if heated up.
not to be picky... but those burs could only cause pre-ignition, not detonation..
Old Jul 3, 2003 | 09:36 AM
struppi's Avatar
Default Re: Carbon Deposit on used pistons (martini)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by martini &raquo;</TD></TR><TR><TD CLASS="quote">
not to be picky... but those burs could only cause pre-ignition, not detonation..</TD></TR></TABLE>
I looked it up and yes, pre-ignition and detonation are not the same thing, but pre-ignition can cause or contribute to detonation. Pre-ignition is the igniting of the fuel before the spark plug fires due to hot spots in the engine. Detonation is an erratic combustion with multiple flame fronts colliding to suddenly increase cylinder pressure. This erratic combustion can be caused my a number or combination of things that lead to excessive heat or pressure in the engine resulting in auto-ignition and multiple flame fronts.
Old Jul 3, 2003 | 10:27 AM
976's Avatar
976
New User
Put some peanut butter on them, bring it over and have my dog lick it, it will look brand new...
Just playin', brake cleaner will do fine as already pointed out! Use a soft %100 cotton cloth to wipe down after they soak for some time...
93Ls-tegra
Oct 25, 2006 08:10 AM
ToeJam
Aug 9, 2006 04:14 PM
KnowForever
Apr 18, 2005 04:39 PM
Hockey27925
Jan 30, 2005 07:47 AM
SilverDc2
Apr 28, 2004 11:03 PM
