car works lean
Old Sep 10, 2005 | 07:40 PM
alispoon's Avatar
Default car works lean
hey few days ago i diagnosed my car(98 civic cx) since the engine check was on.
so the code that came out told me that it works lean. so i went out and changed the fuel filter. and after that i reset the computer.so the engine check was off for a day or two, then it went back on and the car hesitates just like before.
I was wondering if this has happend to anyone else who solved this problem before.
[<U>B]CODE:[/B]</U> P0171 SYSTEM TOO LEAN (BANK 1)
Thanks
Modified by alispoon at 6:04 AM 10/2/2005
Old Sep 11, 2005 | 12:44 AM
JDMOrangeFever's Avatar
Default Re: car works lean (alispoon)
It could be a few things.. make sure you have adequate fuel pressure check regulator , Check the injectors.. may be clogged.. test your fuel pump maybe its starting to go out.. How does the car start when cold? Does it have long cranking? Also was there any other codes.. or that the only one?
Old Sep 11, 2005 | 06:26 AM
alispoon's Avatar
Default Re: car works lean (JDMOrangeFever)
yah its been a few days that when the car is cold it takes about 4 to 5 cranks for the car to go on.
Old Sep 12, 2005 | 02:23 PM
alispoon's Avatar
still waiting for a better answer
i need help please.
Old Sep 12, 2005 | 02:43 PM
mipawi's Avatar
check the feed line, if the feed line is bad you will run lean and have low fuel pressure.
Old Sep 12, 2005 | 04:15 PM
rev-speed's Avatar
u either have a vaccum leak or bad o2 sensor
Old Sep 12, 2005 | 05:12 PM
sleepyEK's Avatar
might be your o2 sensor. check it with a wideband, or a pipe sniffer.
Old Sep 14, 2005 | 05:54 PM
alispoon's Avatar
Default Re: car works lean (sleepyEK)
wideband, or a pipe sniffer??????
wats this
Old Sep 15, 2005 | 09:40 AM
sleepyEK's Avatar
i'm talking about the emissions tester, you can tell if your car is really running lean or not by using this or a wideband o2 sensor.
Old Sep 18, 2005 | 04:39 AM
alispoon's Avatar
hey i took out the fuel pump, it was flaw less it looked brand new and inside my gas tank was the same. so i connected it to my battery to see how it sounds. and it sounded very smooth. so i went and took out the fuel injectors. with the fuel rail and every thing.
all around the injectors where oily or i don't like gas build up or something(it was black)
so now i don't know what else it could be.
im gonna get it diagnosed today and see what it says again.
Old Sep 21, 2005 | 05:08 PM
alispoon's Avatar
im so confused i cant find this frikkin problem.
i checked the injectors but i know by just looking at them that doesnt do any good. but i just cleaned it and put it back in and i also took out the fuel pump too and that looked very good. and it was working like a swiss army watch when i conected it to my battry.
Im getting pised off. pleased help if u can
thanks
Old Sep 21, 2005 | 05:30 PM
IMALLSLO's Avatar
Default Re: (alispoon)
What code was it? I am guessing its going to be an O2 problem.
Old Sep 24, 2005 | 05:07 AM
alispoon's Avatar
thats the only thing that i havent checked yet(O2 SENTOR) but the code that i got told me that its working lean. i dont know wat that has to do with the O2
Old Sep 24, 2005 | 06:29 AM
IMALLSLO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alispoon &raquo;</TD></TR><TR><TD CLASS="quote">thats the only thing that i havent checked yet(O2 SENTOR) but the code that i got told me that its working lean. i dont know wat that has to do with the O2 </TD></TR></TABLE>
Never heard of the "working lean" code. Like I asked,what specifically was the code? And if you dont know what an o2 has to do with a car running lean.....maybe you should take your car somewhere to get diagnosed.
Old Oct 2, 2005 | 05:01 AM
alispoon's Avatar
ok i got it diagnosed again with my uncles diangnostics code reader.
and IT SAYS &gt;&gt;&gt;&gt; P0171&lt;&lt;&lt;&lt; so i read in its book and for P0171 it says &gt;&gt;
so now i dont know wat else to do. im still leaning towards the fuel pump more.
there could be somthing rong with it electronicly. that suchs bad)
and yesturday i fulled the tank and put in one of those fuel injector cleaners the black STP one.
but the car hesitated again ones on my way back home from the gas station.
Old Oct 2, 2005 | 07:17 AM
Chiovnidca's Avatar
Checking the fuel presure will tell you alot.
Old Oct 2, 2005 | 10:19 AM
suspendedHatch's Avatar
Default Re: car works lean (Chiovnidca)
Nobody said the fuel filter which is the most obvious possibility.
How's your ignition timing?
How did the fuel pump strainer look when you took it out? Those are real cheap and if you had it out you should have changed it. It makes a difference on these 12+ year old cars.
If there doesn't seem to be a problem with the fuel pump, don't waste your money guessing. You'd be better off taking it somewhere than just throwing parts at it.
Old Oct 2, 2005 | 11:18 AM
alispoon's Avatar
Default Re: car works lean (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">Nobody said the fuel filter which is the most obvious possibility.</TD></TR></TABLE>
i did change the fuel filter. as a matter of fact i cut it open to see how it looks and it was pretty dirty but its still like that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">How did the fuel pump strainer look when you took it out? Those are real cheap and if you had it out you should have changed it. It makes a difference on these 12+ year old cars.</TD></TR></TABLE>
well if ur talking about the filter thing on the pump, i have to say that it was as clean as new so was the pump itself and the inside of the tank. all looked brand new. BY the way my car is a 98 its not a 12+. just so u know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">If there doesn't seem to be a problem with the fuel pump, don't waste your money guessing. You'd be better off taking it somewhere than just throwing parts at it.</TD></TR></TABLE>
and about this, yah im thinking of taking it to honda and let them check it out. but the thing is that i dont want to spend to much on this engine since im changing it to an sir engine next summer.
91 luder
Aug 28, 2012 04:16 PM
B20inDCinLBC
Oct 10, 2008 10:44 PM
gsr converters
Sep 13, 2006 10:08 PM
alispoon
Oct 18, 2005 07:08 AM
