CAR WON'T START!!! STARTER PROBLEM?
So I drove my car yesterday, turned it off and 5 minutes later tried to start it again. The motor cranked over very slowly for about a second or so and stopped... Now when I try to start it it just clicks...
- tried to boost it: nothing but a click
- replaced battery with new one: nothing but a click
- checked terminals and grounds: look ok to me and nothing helped
Power is there to everything else... Just won't crank... It was fine - this is the very first time something like this happened... What could be the problem?
checked them already... anything else? i heard you can try starting the car by connecting the terminals on the starter... anyone know how to do this properly? i see 3 wires on the starter - a thin black one, a plastic capped thick one and another one attached by a bolt... what are they?
take a jumper wire straight from the pos battery terminal to the "thin black wire" tab on the starter. (MAKE SURE THE CAR IS NOT IN GEAR). if it starts up like normal you're are having connection issues with batt, starter ground, who knows, if it doesn't start at all. buy a starter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greenbee »</TD></TR><TR><TD CLASS="quote">take a jumper wire straight from the pos battery terminal to the "thin black wire" tab on the starter. (MAKE SURE THE CAR IS NOT IN GEAR). if it starts up like normal you're are having connection issues with batt, starter ground, who knows, if it doesn't start at all. buy a starter
tried this - all i get is a click - and a short buzz from the starter... car doesn't crank though... so starter is finished?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMoMo »</TD></TR><TR><TD CLASS="quote">check your main relay</TD></TR></TABLE>
since i get a click doesn't that mean the relay is good?
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whatcivic »</TD></TR><TR><TD CLASS="quote">
since i get a click doesn't that mean the relay is good?</TD></TR></TABLE>
True....what about your ground for your thermostat??
True....what about your ground for your thermostat??</TD></TR></TABLE>
checked all the grounds - they look good... i think it is the starter that needs to get replaced...
jorge59la
Sep 16, 2007 06:28 PM
