Car Won't Start, Please Help!
Old Feb 15, 2012 | 10:59 AM
CraigMW's Avatar
Default Car Won't Start, Please Help!
I have an EG hatchback with a F22B1 and I need help getting it running if someone would like to throw out some tips or ideas... I replaced all of the main wiring recently but it does not want to start. I have power (lights and all) but when i turn the key to start it, I hear my fuel pump then it just does one "click" that is coming from the main fuse box that would normally be under the hood (in my case, it is in the dash where the air bag would be). Can anyone identify this problem or possibly point me in the right direction? Any information will be greatly appreciated. Thanks again guys!
Old Feb 15, 2012 | 11:25 AM
turbohatch96y7's Avatar
Default Re: Car Won't Start, Please Help!
Is your battery old? How many volts is it holding? Is your starter solenoidd getting voltage? Where is the click coming from exactly? Are you getting spark to your plugs? If the engine isn't turning over start there get the motor turning then move on.
When you turn your key to crank, voltage goes to your solenoid, tips close and voltage goes to your starter, the starter spins your flywheel and your flywheel is bolted to the crank if your starter isn't spinning check that first. Its most likely your battery or bad wiring.
Old Feb 15, 2012 | 06:22 PM
fcm's Avatar
fcm
Old Fart
https://honda-tech.com/forums/showth...ypass+jump+fcm 94
Old Feb 17, 2012 | 06:45 AM
CraigMW's Avatar
Awesome! Thanks for the info guys! I will be trying all suggestions soon and let you know the outcome.
Thanks for the link fcm... great stuff!
Fresh Ej2
26
Apr 2, 2009 06:19 PM
ef9_pr0jekt
Oct 7, 2007 06:15 PM
CiViC I2aCeI2
Mar 12, 2006 03:53 PM
Mr_Moos
Nov 5, 2005 03:30 AM
jolt-tsp
Oct 31, 2003 04:17 PM
