car wont start and im stumped
Old Jul 16, 2009 | 06:41 PM
si vtec ftw's Avatar
Default car wont start and im stumped
okay heres what happened
put my motor back in and drove it around that night and the next day not a problem
then that evening when im driving it stalls when i push the clutch in then starts back up.
did it a few times then when i got to where i was going i parked then when i went to start it a few hours later, it starts then instantly dies, maybe 3 times
now it just wont start at all.
i have spark, i have fuel, its not the ecu or the dizzy i switched both. its not the main relay. and im pretty sure the motor didnt jump timing.
what the heck am i missing?
Old Jul 16, 2009 | 10:22 PM
delsolproblems's Avatar
Default Re: car wont start and im stumped
Check the grounds, fuel pressure, air filter, MAP sensor voltage and compression. One of those tests will surely provide more information. Are any cylinders firing at all- any popping or sputtering when you crank it?
Old Jul 17, 2009 | 05:13 AM
grounds are good, and i definitely have compression, the motor has 2k on it. it does backfire at times because of the dizzy timing being a little off but i got it back in about th eright spot. it pops a little but not a whole lot, everything is in proper order it just wont start
Old Jul 17, 2009 | 06:40 PM
KWayRacing's Avatar
Sounds like a mechanical problem if everything is in proper order. Just b/c your moto has 2k on it doesn't mean that it has compression unless you check it and know instead of assume that it does. Ign timing being just a tad off would not cause the car to misfire. Are the injectors pulsing?
Old Jul 18, 2009 | 12:30 AM
NAcoupeNA's Avatar
what do your plugs look like? have u pulled them? just because you're getting fuel doesnt mean you're good. you could've ran rich and fouled your plugs. any CEL's?
91DA buffalo
Aug 2, 2011 12:06 PM
kevinm1981
Jul 12, 2009 01:40 PM
d15bflat
Jul 7, 2009 12:29 PM
Lan
May 23, 2005 12:56 PM
93b20z
Apr 10, 2005 07:54 AM
