car won't start
car wont start. i think it the fuel pump i took the fuel line off to see if i was getting fuel to the engine and for some reason im not getting fuel i tried to see if the pump made any noise but i couldnt hear any so i took it out is their any way to test it? the only other thing i know that i could be is the relay next to the fuse box, but how do you test it? is there anything else it could be?
Test it by putting 12v power to it - see if it runs. Don't make sparks with the gas tank open...
Or, check to see if you get 12v power at the wires that were connected to the pump. If you don't, then see if the main relay closes. You should get a manual for your car for the details. Might not be the same as mine.
Broke_not_built
Aug 22, 2011 10:40 AM
bimmeracer
Nov 3, 2008 08:46 PM
