Car won't start
Old Nov 10, 2002 | 01:16 PM
Rain_man's Avatar
New User
Default Car won't start
I'm having problems starting my car. While I was driving the car all of a sudden died and won't start. I replaced the coil, spark plug wires, cap and rotor and am getting no spark when I pull the plug wire and touch it to the block. The car is cranking too.
Any ideas?
Old Nov 10, 2002 | 02:10 PM
Desslok's Avatar
Default Re: Car won't start (DarksideDC4)
Did you check all the fuses? Definitely check ECU fuse under hood, but check them all. Another likely culprit is ignitter.
Old Nov 10, 2002 | 02:45 PM
Stryker908's Avatar
Default Re: Car won't start (sp)
haha about 3 months ago I was showing a buddy what it was to " pop the clutch " he had never seen it done before ... Long story short when i shut the car off (rolling down a hill ) and tried to pop it .. the car died..... it would try to turn over but couldent get there ..... long story short ... I tryed jumping it didnt happen called a toe truck ... turns out that all my showing off had bounced the bat fuse loose .... (under the hood )
Old Nov 10, 2002 | 04:17 PM
Rain_man's Avatar
New User
Default Re: Car won't start (JDM_SIR_II)
checked all the fuses, we're guessing it might be the timing belt.
Old Nov 10, 2002 | 04:20 PM
Nameless RB26's Avatar
..and you haven't checked it yet?
Also, did you get any check engine lights?
Old Nov 10, 2002 | 04:59 PM
Rain_man's Avatar
New User
Default Re: Car won't start (Nameless)
we played around with it earlier today, but gave up. Just thought of timing belt right now.
He did get a bunch of lights on the dashboard when the car died.
Not my car though, it's my friends. An 86 Toyota Camry, so...
[Modified by DarksideDC4, 5:59 PM 11/10/2002]
Old Nov 11, 2002 | 02:15 PM
RAWB's Avatar
Could be the infamous MAIN FUEL RELAY.
Old Nov 11, 2002 | 02:17 PM
Hondasaurs's Avatar
Any ideas?
You may have a bad ignitor if you replaced all of those things and the car still wont spark. The ignitor is located inside of the distributer. It will run you $80-90 for a new one if in fact that is your problem.
Old Nov 11, 2002 | 02:23 PM
hornetd23's Avatar
Default Re: Car won't start (ZC_CRX)
Same problem here tought it was the ignitor toke off my timing belt cover low and behold one busted timing belt
dirrtybirdy
Mar 28, 2010 01:43 PM
hybridmath
30
Jul 20, 2008 03:38 PM
Stevegunit16
Mar 17, 2007 08:59 PM
JDMlyfestyle
22
Jan 9, 2004 10:36 AM
hagrid
Nov 25, 2002 03:27 PM
