car wont start!!!
Old Jan 24, 2002 | 04:21 PM
big pete's Avatar
Default car wont start!!!
i changed my ignitor two days ago and now it doesnt start(b16 crx).......i dont know wtf is wrong with it.......it cranks but doenst start.......the distributor isnt backwards cuz i flipped it a couple times already just to make sure.....i changed the ignitor cuz the tach was starting to jump around......i also replaced the coil for a working one and still nothing.....any suggestions??
Old Jan 24, 2002 | 05:43 PM
flymecourageously's Avatar
New User
Default Re: car wont start!!! (big pete)
the battery?
Old Jan 24, 2002 | 07:04 PM
Kamin's Avatar
Default Re: car wont start!!! (flymecourageously)
um if it was the battery it wouldnt crank at all...
are you getting a spark?
Old Jan 24, 2002 | 07:59 PM
mantic6t9's Avatar
You may have a bad main relay. I had this happen to my in my 93 si hb. The engine would turn but it wouldn't start. Sometimes after messing with it for a while i could get it to start. It really only did it when the car had been sitting in the sun for a while. I replaced it and it fixed the problem. Later..
Old Jan 24, 2002 | 08:11 PM
bob01721's Avatar
Default Re: car wont start!!! (mantic6t9)
"You may have a bad main relay." Good point! How do you know the problem is with the ignition? Have you checked for spark at the plug wires? If you get a fat blue spark from the end of the plug wires, you're ignition is working fine -- check fuel next.
The main relay controls the fuel pump. It's also a "common failure" item.
Don't just slap new parts on it unless (1) you KNOW the "old" one is bad or (2) you don't mind throwing money away.
Old Jan 24, 2002 | 10:13 PM
big pete's Avatar
Default Re: car wont start!!! (bob01721)
well i know its ignition cuz it wouldnt start after i put in the new ignitor....how do you check for spark at the wires??.........well people said my ignitor was goin bad cuz the tach started jumping around.....thanks guys ill try what you guys said.....i could hear the fuel pump turn on when i turn the key so i dont think its fuel
[Modified by big pete, 7:14 AM 1/25/2002]
Old Jan 24, 2002 | 11:03 PM
OneThirtyEight's Avatar
I had the ignitor problem, it WAS the ignitor, but the ignitor wasent bad, the blue (tach) wire, just kept comming loose, so I soldered the wires down, and its fine now. All this after I bought a new ignitor, did you connect all the wires correctly in the ignitor?
Old Jan 24, 2002 | 11:06 PM
obd1canobie's Avatar
New User
Default Re: car wont start!!! (97blackteg)
Check the dist cap. Make sure you didn't bust the carbon pickup that goes into the coil.
Old Jan 25, 2002 | 04:06 PM
BadBranez's Avatar
Make sure the wires on the igniter are installed correctly...did the car ever start after you replaced the igniter? If not, try switching the blue and green wires. The main relay should only act up while it is hot inside the car.
slow joe
23
Jan 6, 2010 11:08 AM
7panget
Nov 15, 2007 01:32 PM
c-y-nickel
Mar 16, 2004 04:24 PM
hmonglonertim
Aug 10, 2002 05:44 AM
HYBRIDGSiR
Nov 23, 2001 07:32 AM
