Car will not turn over LOOK
Old Nov 27, 2007 | 01:40 PM
Akalima's Avatar
Default Car will not turn over LOOK
K I have a 99 integra gsr that is turboed. I had been having troubles with the dizzy and coil. The car would start to miss at 5000rpm after driving the car in hi boost for long periods but after i would restart the car the problem reset itself. On halloween i drove the car up the street and it would not start after that. It would turn over but would not fire. The IAC was making wierd noises but figured it was the dizzy. I bought a new DISTRIBUTOR KING dizzy because of higher heat tolerances. I just put the new one in and the car will not turn over. Ive got power and can hear the injectors putting fule in the car but no spark. And the injectors will continually put fuel into the engine as long as i have the key turned. Thanks for looking and ur help.
Old Nov 27, 2007 | 04:20 PM
Akalima's Avatar
Default Re: Car will not turn over LOOK (Akalima)
BUMP
Old Nov 28, 2007 | 12:42 PM
95 integra's Avatar
Check your fuses and relays.
Old Nov 28, 2007 | 01:06 PM
Akalima's Avatar
Default Re: Car will not turn over LOOK (95 integra)
Checked all the fuses but unsure of how to check the relays. And there are only fuses in the engine bay that r related to the ignition is that correct.
Old Nov 29, 2007 | 08:29 AM
Akalima's Avatar
Anyone?
Old Nov 29, 2007 | 08:56 AM
King V's Avatar
What do you mean by<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Akalima &raquo;</TD></TR><TR><TD CLASS="quote">. And the injectors will continually put fuel into the engine as long as i have the key turned. Thanks for looking and ur help.</TD></TR></TABLE>? You turn the key to "run" and the injectors fire?
Old Dec 1, 2007 | 06:31 AM
Akalima's Avatar
Default Re: Car will not turn over LOOK (King V)
Yes. u know hen u turn ur key in any Honda jsut before u start it u can hear the buzing of the injectors putting fuel into the engine. Well it continually does that almost as if the car thinks that is is starting and to give it more fuel.
Old Dec 2, 2007 | 07:26 AM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Akalima &raquo;</TD></TR><TR><TD CLASS="quote">Yes. u know hen u turn ur key in any Honda jsut before u start it u can hear the buzing of the injectors putting fuel into the engine. Well it continually does that almost as if the car thinks that is is starting and to give it more fuel.</TD></TR></TABLE>
The buzzing you hear is the fuel pump, not your injectors.
Old Dec 2, 2007 | 12:53 PM
Akalima's Avatar
Default Re: Car will not turn over LOOK (gibsanez)
Okay thanks i thought it was coming from the engine bay. So what does that mean. The pumps working feeding the injectors and whats missing? Power? The injectors not feeding and no spark. So whats not working?
Old Dec 3, 2007 | 12:09 AM
ek4shizzle's Avatar
so when you turn the key to ON position, does the fuel pump for 2 seconds or does it stay on?? its only suppose to stay on for 2 seconds until you start the engine. are you sure youre not getting any spark. pull the spark plug and ground it, then crank it and see if it sparks. if your fuel stays on maybe you flooded the engine with too much fuel.
Old Dec 5, 2007 | 03:49 PM
Akalima's Avatar
Default Re: Car will not turn over LOOK (ek4shizzle)
The fuel pump is on for a couple of secs and then cuts out and iff i have the key still in the start position the pump will start up again. And there is no spark the engine does not even try to run over. Absolutley nothing happens
Old Dec 5, 2007 | 04:10 PM
averyvm's Avatar
if the motor does not turn over then your not going to get any spark
Old Dec 5, 2007 | 06:08 PM
dude_123's Avatar
Did you even check if you have B+ to your coil/distributor? Also check your cam timing, it might have jumped a lot of tooth or worth case scenario...spun bearings.
Modified by dude_123 at 7:22 PM 12/5/2007
Old Dec 6, 2007 | 05:51 PM
Akalima's Avatar
Default Re: Car will not turn over LOOK (dude_123)
B+ ? What do u mean. And the engine would still turn over. The enigne does not even try to move. Absolutly nothing happens. Nothing moving no sounds except for the fuel pump.
raidacaipo
Aug 25, 2014 01:04 PM
95PreludeJDM
Nov 29, 2010 09:50 AM
civic46
11
Sep 12, 2010 05:25 PM
stdefhatch
May 6, 2006 01:54 AM
