car takes a long time to start
when my car sits out for a day or sits out for a while it takes very long to start.
my battery is good.
took my starter to autozone to check it out and the guy said it worked fine.
but, i don't know why it's doing this.
i sit in my car, step on the clutch and try to start it and the radio will turn on along with the lights just fine, but i'd be sitting there trying to turn the ignition and it just clicks, most times i'd have to keep trying 20+ times, then it'll start. it doesn't crank, no grinds either. just click, click, click... till it wants to turn on.
any ideas?
my battery is good.
any ideas?
my battery is good.
any ideas?
my battery is good.
any ideas?
Batteries can be bad from the factory, though not common. Check your battery voltage with nothing on. Leave a volt meter on it and turn on the headlights and check the volts, and then, off the lights and look at the volts when you try to turn the starter over.
so, you think my battery can go bad after a couple months of it working well?
If you don't know what you are doing, then it might be a challenge. But starting a car with AEM should be perfect if you know what you are doing. The OP didn't say anything about an aftermarket engine management, that's why I asked.
nighttrain33
10
Feb 25, 2007 08:10 PM
