Car starts then dies
Old Apr 17, 2013 | 11:24 PM
thekid2390's Avatar
Default Car starts then dies
I have a 1999 ek with a lsv i had a idle issue i finally fixed it i got all new hoses for my iacv and fitv the car turned on after i did that i let it sit over night and this morning when i had to go to work the car didnt want to stay on. It would turn over and start but just for a few seconds but if i pressed the gas it would stay on as long as i was pressing the gas...i check my ingition connections and they looked good any advice for when k get off of work i was seraching the internet and people where sayings that it the switch going bad is there anyway to check that before i order one
Old Apr 18, 2013 | 05:19 AM
Wolb's Avatar
Default Re: Car starts then dies
So you got all new vacuum lines for the whole engine? Because it sounds like a real bad vacuum leak.
Old Apr 18, 2013 | 06:00 AM
thekid2390's Avatar
No just coolant hoses
Old Apr 18, 2013 | 10:09 AM
Wolb's Avatar
I would def. check out all the vacuum lines and check for leaks. Possibly going to a shop and having them do a smoke test on it. There is also the carb cleaner test that you can do on it but to know for sure the smoke test is the only way.
Old Apr 21, 2013 | 06:39 AM
thekid2390's Avatar
http://www.keek.com/!TSYMbab this is what my car is doing know when it hits 1500rmp when i hit my iacv nothing changes and when i disconnect my iacv the rmps dont drop so this mean a bad iacv right? But why does it sound like its hitting rev limiter
Old Apr 21, 2013 | 06:58 AM
hiSKOOB's Avatar
the rev limiter sound you're getting could be a bad sensor or sometimes a bad vacuum leak like Wolb said. Is the motor OBDII? If so have you plugged it up to see if you're getting any codes?
Old Apr 21, 2013 | 07:18 AM
thekid2390's Avatar
I cant get any cel cuz the guy that had it before me did something to the ecu so it wont throw any cel which is making this trouble shooting that much harder .... I have already check for vac leaks when i cover the top hole in the tb it shuts off so i dont think its a leak... I took iacv off and cleaned it with carb cleaner guess it just bad am change it... The car is obdII with a p28 with a jumper harness
Old Apr 21, 2013 | 09:12 AM
K24Plus's Avatar
Same problem with my MR2 MK1, does yours stutter after a few seconds and die out? It was something to to with the temperature or the idle. Its fine now as the idle control valve needs to be set right. dont know where it is in the EK's engine but you'd need a flat head screwdriver to turn it.
DAprojectTuRtle
Feb 6, 2015 09:40 AM
crazyguy
Sep 5, 2007 02:13 PM
IntEGNYC
Jun 19, 2003 06:53 PM
mrnicolas
Oct 31, 2002 02:13 AM
