Car stalls at stop
Old Dec 31, 2006 | 05:57 PM
justint's Avatar
Default Car stalls at stop
I have a 98 CR-V with a JRSC and fuel management that I know needs to be changed (crome on the way) right now has FMU and VAFC2.
I recently changed out a bad PCV valve and I am not sure if this is a result of that or not, but the car stalls when you come to a stop. The RPM's drop real low and it just dies. Could this be something to do with the PCV swap, my Fuel setup, or something else like a sensor?
Old Dec 31, 2006 | 08:51 PM
turtleman321's Avatar
most likely fuel. my car did it from a faulty fuel filter.
Old Jan 1, 2007 | 08:47 AM
JDM94EG28's Avatar
Default Re: Car stalls at stop (justint)
when the car dies,does it the fuel pump pry right back up?
Old Jan 1, 2007 | 08:57 AM
justint's Avatar
Default Re: Car stalls at stop (JDM94EG28)
If you mean does the fuel pump fire right up..yes it does.
Old Jan 1, 2007 | 09:36 AM
bart2546's Avatar
Check the fuel filter and since you stated you have a VAFC, if you haven't done so/tuned it yourself anyway check the fuel curves to see if it's trying to dump too much fuel into the motor at lower RPM's.
sasinorm01
Mar 19, 2015 09:28 AM
DevontElan
Feb 14, 2008 03:16 PM
blinger
Sep 1, 2007 10:35 PM
crnimacak
Apr 21, 2006 10:11 PM
eg6_lsi
Mar 25, 2004 10:29 PM
