Car running richer after intake?
Old Aug 7, 2009 | 02:28 PM
20ls01's Avatar
Default Car running richer after intake?
i installed an AEM intake for my integra LS and noticed my exhaust tip is accumulating black powder/soot at a very fast rate. I've reset the ecu after the install and does the same. I put back the OEM intake and reset the ECU and it is doing it still. It normally is very clean but after few days of driving, my finger will turn black if i run my finger through the exhaust tip.
does anyone know why it is doing this and how to fix it? ive triple checked my work, there are no air/vacuum leaks or anything.
Old Aug 7, 2009 | 08:44 PM
Scott_Tucker's Avatar
Default Re: Car running richer after intake?
Its pretty common for carbon to accumulate on the inside of an exhaust tip. How does the engine run?
Old Aug 7, 2009 | 09:20 PM
Ruben19's Avatar
r you burning oil?
Old Aug 7, 2009 | 09:34 PM
Do you know you are running rich or are you just speculating?
Old Aug 8, 2009 | 09:17 AM
TOO MUCH TORQUE's Avatar
i am speculating(black soot = unburned gas?).........my engine runs very well, i dont burn any oil and i am running valvoline synthetic oil.
right after i put in the intake, my exhaust tip will accumulate soot fast, before it did not.
oh btw, this is shifting below 3.2k rpms !!!
im just worried about long term effects like o2 sensors and such.............
Old Aug 9, 2009 | 10:09 AM
Black soot does not equal unburned gas. It is free carbon which is a byproduct of combustion and may be normal. I honestly wouldn't worry about it unless you think the engine runs different than before you put the intake on.
Old Feb 7, 2021 | 07:15 PM
kyleahrens11's Avatar
currently have 02 Rsx with k20z1 swap. (out of 06) HKS exhaust, DC headers, and AEG cold air intake. been running mobile 1 oil and burns about at least a quart between every oil change. other than changing oil does anyone have any suggestions or things I could possible do to vehicle to make it run great. car also has Hondata ecu. anything helps. thanks
Kyle
Old Feb 7, 2021 | 09:24 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Kyle
It is best to create your own thread and ask this question... not hijack others and ask in multiple threads. I answered in your other one.
mark31kiss
10
Feb 8, 2021 02:10 PM
j_polk2008
Oct 6, 2008 11:08 AM
lude98SH
Sep 20, 2005 09:05 AM
.M.
May 26, 2004 01:31 PM
1.8T_EG
Aug 16, 2002 06:40 AM
