CAR NOT STARTING!!! odd symptoms.....
Old Jul 30, 2004 | 06:46 PM
92hatchattack's Avatar
Default CAR NOT STARTING!!! odd symptoms.....
ok ... here we go ..... 92 cx hatch .... had a b16, got stolen, now a d15b7 sits inside...
heres whats happening ....... when i turn the key onto acc. everything comes on as usualy .. accesories/fuel pump/ the works ...
as soon as i go to start i get a CLICK!....... after that i turn the key off and go back to acc and there will be no power at all!!! I t takes a few minutes before it seems to reset and then the proccess starts all over again ...
i have checked my connections and i have checked my grounds an what not ....
could this be a main relay problem, or is the main relay just fuel related???
how bout a bad starter cut-off switch or relay or whatever???
please guys, give me a hand so i can get this thing alive again!!!
Joe
Modified by 92hatchattack at 1:42 AM 7/31/2004
Old Jul 30, 2004 | 09:42 PM
Default Re: CAR NOT STARTING!!! odd symptoms..... (92hatchattack)
up for the night!
Old Jul 30, 2004 | 10:03 PM
murtnabila's Avatar
sounds like you have some wrong wires shorting out o somethin.
Old Jul 31, 2004 | 07:30 AM
Default Re: CAR NOT STARTING!!! odd symptoms..... (murtnabila)
i dont know .... cause the car would run fine for 2 months, then do this, then run fine for 2 months and do this, then run fine again .... i cant figure it out ...
Old Aug 2, 2004 | 06:59 AM
up
Old Aug 2, 2004 | 07:38 AM
navin's Avatar
my car is doing some what the same, except the fuel pump will not prime if I start the car and drive around for awhile..
I have to let it cool down for the pump to prime, new relay is like $45ish from honda
White98LS
Jul 14, 2007 07:46 AM
NazVil86
Oct 10, 2006 06:44 PM
shreddinryguy
Jun 26, 2005 02:03 PM
hebelect
Mar 22, 2005 01:43 PM
KoRE
Jul 10, 2004 06:18 AM
