car dies
Old Sep 6, 2006 | 08:00 PM
JDMtype Eg6's Avatar
Default car dies
sometimes when i turn on my car, then turn my headlights on my car dies. i cleanded the ground from the battery to the body and it worked fine. but now the problem happens again but rarlely.
when i wiggle the ground wire a little the problem goes away. is this just a bad ground wire??
Old Sep 13, 2006 | 03:27 PM
haji's Avatar
Default Re: car dies (JDMtype Eg6)
sounds like a corroded wire... or bad connection... check ur alternator for loose connections.. and battery voltage with all acc. on at idle should be around 13.5-14.5volts.
JasinC19
11
Jun 23, 2013 10:40 PM
blackk20dc5
Feb 11, 2010 06:33 AM
EJason
Mar 6, 2009 11:04 AM
CLE
Mar 16, 2006 03:38 PM
96b18c
Jun 3, 2004 07:29 PM
