Car bogs out when I give it gas
Old May 22, 2003 | 02:13 PM
91integ23's Avatar
Default Car bogs out when I give it gas
Does anyone know why my car bogs out like if there were no gas going in to the motor. When I am on the freeway it begins to bog and as I give it more gas it does not go anywhere. My comp. is throwing a code 1 and a code 2. I checked my O2 sensor but I don't know what a code 2 is. I also checked my spark and that is not the problem. This is a B16A1 motor.
Old May 23, 2003 | 02:01 AM
BR's Avatar
BR
Default Re: Car bogs out when I give it gas (91integ23)
Code 1 and 2 are both O2 sensors. The b16a came with 2 O2 sensors on it...
You should try replacing your O2 sensor to start and if you dont have another one then you need to splice the wire from your ECU onto your O2 sensor.
That will trick your ECU into thinking that you are actually running 2 O2 sensors.
Later,
BR
Old May 23, 2003 | 02:17 AM
Kamin's Avatar
Default Re: Car bogs out when I give it gas (BR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BR &raquo;</TD></TR><TR><TD CLASS="quote">Code 1 and 2 are both O2 sensors. The b16a came with 2 O2 sensors on it...
Nope sorry, 1 o2 sensor on b16's (not sure on the b16a2, 99+ SI engine, may have 2 because of obdII.)
but an o2 sensor should cause a bogging problem unless you are running REALLY rich to begin with. i ran without one on my b16 for about 3 months, never had a problem other than 18mpg.
Old May 23, 2003 | 02:21 AM
BR's Avatar
BR
Default Re: Car bogs out when I give it gas (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">
Nope sorry, 1 o2 sensor on b16's (not sure on the b16a2, 99+ SI engine, may have 2 because of obdII.)</TD></TR></TABLE>I dont know about the 99+ Si, but the JDM first gen b16a1 came with 2 O2 sensors on the exhaust manifold. One primary and one secondary.
If I had a camera I would go out to my garage and take a picture of one for you.
Later,
BR
Old May 23, 2003 | 02:23 AM
Kamin's Avatar
are we talking about a first gen? damn i hate JDM engines they need to specify hehe
Old May 23, 2003 | 02:28 AM
BR's Avatar
BR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">are we talking about a first gen? damn i hate JDM engines they need to specify hehe</TD></TR></TABLE>It isnt the engine that matters, it is the ECU that he is using. Considering he has a 91 integra (by what his screen name is) I know that he is using either a PR3 or a PWO obd0 ECU, both of which came out of the first gen b16's in Japan which use 2 O2 sensors.
Later,
BR
Old May 23, 2003 | 12:02 PM
spoon063's Avatar
i jsut had the same problem with my car..it ran fine at about 20% throttle... once i went to get on it it bogged down and cut off basically... it turend out the furl pump want giving out enough pressure... try taking a tester and reading your pressure
andyvaj
May 2, 2007 06:28 AM
SwiftTypeR
Feb 26, 2007 01:20 PM
Shakes
Apr 28, 2004 08:45 PM
ironchef25
Feb 3, 2004 04:32 PM
fast[R]
Apr 24, 2002 04:58 PM
