Can't Get Caliper Bracket Bolt Off
Old Apr 22, 2006 | 09:00 AM
vinuneuro's Avatar
Default Can't Get Caliper Bracket Bolt Off
I need to get the rotor out. Do you guys normally remove the caliper bracket bolt out by hand? It says the bolt torque is 80 lb-ft in the Helms. It's in an awkward position bc it points away from you and there's not much room. I can't for the life of me get it out with my ratchet. Do I need an air ratchet? Most air ratchets only go to 50 lb-ft.
Old Apr 22, 2006 | 04:26 PM
94gsr18kid's Avatar
Default Re: Can't Get Caliper Bracket Bolt Off (vinuneuro)
They'll usually go with a 1/2" breaker bar. Another way would put a wrench on it and pound the wrench with a hammer until it gives.
Old Apr 23, 2006 | 04:46 PM
dpetro1's Avatar
Default Re: Can't Get Caliper Bracket Bolt Off (94gsr18kid)
breaker bar or bfh (big f'ing hammer) FTW!!
Old Apr 25, 2006 | 12:28 AM
sporkcrx's Avatar
Default Re: Can't Get Caliper Bracket Bolt Off (dpetro1)
air rachet won't do more than you'll be able to turn, a gun yes, but not a rachet. Either use a bigger rachet for more leverage, a stronger person, or use wrenches and double them up to gain leverage.
Old Apr 25, 2006 | 11:20 AM
Lsos's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">I need to get the rotor out. Do you guys normally remove the caliper bracket bolt out by hand? It says the bolt torque is 80 lb-ft in the Helms. It's in an awkward position bc it points away from you and there's not much room. I can't for the life of me get it out with my ratchet. Do I need an air ratchet? Most air ratchets only go to 50 lb-ft. </TD></TR></TABLE>
Turn the steering wheel to give yourself more room, if you haven't done so yet. Try using a big hammer, or more leverage. A trick I sometimes used is actually using a car jack to turn a wrench. Just make sure you're turning the bolt the right way. I did that once the wrong way when i was first learning about cars.
Old Jul 30, 2012 | 09:16 AM
bertpalmer's Avatar
i have a similar problem on a 2002 crv but rear caliper bracket bolt 14mm but it has been rounded off(butchered) so am really struggling,any advice,i am a novice diy with just a socket set and would really like to beat this
vinuneuro
Apr 22, 2006 08:43 PM
vinuneuro
Apr 22, 2006 12:12 PM
vinuneuro
Apr 22, 2006 09:11 AM
.Ry
14
Sep 15, 2005 10:14 AM
grenthang
Dec 4, 2004 11:33 PM
