Can you switch 02 sensors?
Old Aug 18, 2003 | 08:52 PM
ramz7887's Avatar
Default Can you switch 02 sensors?
Are the 02 sensors on a 98 civic interchangable between the front and the back? Also does anyone have a cheap used honda one?
Old Aug 18, 2003 | 09:06 PM
PHiZ's Avatar
Default Re: Can you switch 02 sensors? (ramz7887)
I heard no.
-PHiZ
Part #s would tell you.
Old Aug 19, 2003 | 05:38 AM
EE_Chris's Avatar
Default Re: Can you switch 02 sensors? (PHiZ)
The part #'s are indeed different, as is the price, with the 2nd O2 being more expensive. The only difference between the two, visibly, is the insulative jacket on the 2nd O2.
Old Aug 19, 2003 | 09:50 AM
PHiZ's Avatar
Default Re: Can you switch 02 sensors? (EE_Chris)
well it would make sense for them to be different. Because one is tuned for before the cat, and one for after...
They are indeed different internally, AFAIK.
-PHiZ
Old Aug 19, 2003 | 10:54 AM
ATS_Antone's Avatar
they cannot be changed form front to back. One is a o2 sensor and the rear one is a monitor sensor. If you switch them then you will get a cel
Old Aug 19, 2003 | 11:25 AM
ramz7887's Avatar
Default Re: Can you switch 02 sensors? (antone)
So then the car doesn't have 2 o2 sensors. IT has one and then a monitor sensor? So if i get a cel for a o2 sensor it must be the front?
Old Aug 19, 2003 | 11:30 AM
ATS_Antone's Avatar
no not neccesarily. Just check for a proper voltage sweep when the car is hot from the 02's
Old Aug 19, 2003 | 11:31 AM
ramz7887's Avatar
I was wondering about 02 sensors because i got a cel of p0133 and i don't kknow if its the sensor or the ecu?
Old Aug 19, 2003 | 01:18 PM
Highrevs99's Avatar
I have switched them and the car ran fine . I think the reason for the different number is the plug for the floor and the wires are shorter but I do know it worked in my 99 si and we did it to another 99 si and no problems .
anothersickhatch
May 15, 2004 10:22 PM
gsrvtechatch93
Mar 29, 2004 08:48 PM
Loveless
Jun 13, 2003 08:44 PM
Etylorcen
May 6, 2002 04:28 PM
